Old 10-17-2018, 08:17 AM   #1
BigDwa
C20 brake conversion question
Howdy, first time working on a disc brake conversion and I have been reading through many of the threads. I have a 1969 Chevy C20.
I am leaning towards the Performance Online C20 8 lug disc conversion kit. I want to use the 2 1/2 drop spindles when I make the disc conversion.
However, there is a note that I am having a hard time understanding. The note is: Note: May not work with factory 15" drum brake wheels. Moves wheels out .75", 3/4" on each side
I do have 15" wheels on the truck currently. Don't believe they are stock rims as they are not steel rims but aluminum. Would prefer not to replace rims at this time if possible. What do I need to check? Anyone else used this kit before and if so did you run into anything unexpected?
Link to the Performance Online disc conversion Kit: https://www.performanceonline.com/19...-8-Lug-Deluxe/
Thanks in advance.. David A.
Last edited by BigDwa; 10-17-2018 at 08:18 AM. Reason: added additional information.
BigDwa is offline   Reply With Quote
Old 10-17-2018, 10:28 AM   #2
whitedog76
Re: C20 brake conversion question
15" aluminum 8 lugs? Don't believe I've ever seen a set.
Anyway, The problem with some of the kits mainly has to do with steel rims. Factory steel rims have a drop down where the center is welded to it. Alot of times the caliper will hit the drop down. If your aluminum rims don't have the drop down, you should be fine.
whitedog76 is offline   Reply With Quote
Old 10-17-2018, 11:10 AM   #3
BigDwa
My mistake, they are 16" rims... Not sure why I had 15" stuck in my head.
Thanks for the reply.
Old 10-18-2018, 10:03 AM   #4
SCOTI
SCOTI's Avatar
Factory drum brake wheels typically won't clear the disc brake calipers.
The 16" aluminum wheels mentioned are (most likely) aftermarket so I would bet they were built for a disc brake application.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 01-23-2019, 07:45 PM   #5
tdangle
tdangle's Avatar
Did you end up using this kit? If so how did it work out? I'm looking at the same thing for my C20
Terry
1970 C20 Custom Camper, 350/2004R, Dana 60, factory AC, side tool box
tdangle is offline   Reply With Quote
Old 01-24-2019, 11:09 AM   #6
BigDwa
I did end up purchasing the kit over the holidays when they had their sale going on. With the holidays and getting back into the new year, have not had an opportunity to install the kit. The kit looks good.
Old 01-25-2019, 01:03 PM   #7
tdangle
tdangle's Avatar
I did some quick rough math on buying all the parts included in their "kit" and it doesn't really look like it is overpriced. And when you factor in the headache factor it may be a bargain. Originally I was looking at picking up spindles and such from the junk yard (assuming I could find them) and then using all new brake components. This kit looks like the way to go. Keep us informed as to how everything works out.
Terry
Old 01-25-2019, 01:09 PM   #8
BigDwa
Good luck finding used spindle unless someone on the forum has them. I am in the DFW metroplex and spent a good portion of a day calling around trying to find used spindles from a pick a part place... I looked for 71-72 spindles as well as 73-87 with no luck...
This is all new to me but seems like the junkyards keep certain years of cars and then it is not profitable to keep older cars.
I would agree, I went through the process of adding up the piece parts to see if I could save a few dollars here and there, but in the long run its all in the kit and for a good price. Of course, I saved more with their holiday sale.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
