Old 01-31-2019, 05:56 PM   #26
GMC Guy
GMC Guy's Avatar
Re: steering too light-74 Blazer
Just took the truck for a test drive with the new valve and it performs perfectly! exactly the correct amount of assist i was hoping for. Order yourself one ASAP.
Last thing will be the steering box to tighten up the ratio, but that can wait awhile now
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 01-31-2019, 09:28 PM   #27
frenchy51
frenchy51's Avatar
Just placed my order-Thanks for all your help!
1972 Highlander PAC B 400BB
1974 K5 Blazer-6.0 swap
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 02-08-2019, 12:32 PM   #28
stanski
Originally Posted by GMC Guy View Post
https://www.speedwaymotors.com/Musta...-GPM,5852.html
this is the one i ordered, looked like the only option for use with original style flared hose ends. All the others have a 6an fitting
Here's the adapter
https://www.speedwaymotors.com/O-Rin...ter,24682.html
Greg and Frenchy, I was away for a while. These 2 parts from Speedway are the ones you need. These work on all of the can of ham type PS pumps.
Don't forget to post back your results.
stanski is offline   Reply With Quote
Old 02-08-2019, 09:07 PM   #29
stanski
Just one more thing to add to this discussion. You can take this to another level which I have not tried, that is dialing in the exact steering feel you desire. Turn One Steering also sells a flow reducer rated at 1.8 gpm or will custom machine one at any rate you order. If you look at the valve, the flow rate is determined by the size of the hole in the valve bore, bigger the hole, higher the flow. I think 1.8 gpm might be too low and could cause loss of assist or jerky assist at low rpms, but if you took that 1.8 gpm valve and drilled out the hole slightly larger in small increments you may arrive at a flow rate with a great feel which is less than the 2.4 gpm Speedway valve? Just a thought, something someone may wish to experiment with.
Old 02-09-2019, 01:58 AM   #30
LT7A
Johnny say "under-drive". Why wouldn't you find a bigger pulley or a marketed underdrive pulley and lose some parasitical drag at the same time? Seems like 25% underdriven would be in the neighborhood.
Old 02-09-2019, 09:37 AM   #31
jkk
jkk's Avatar
Dumb question which end of the hose do the speedway parts go in pump side or steering box side?
jkk is offline   Reply With Quote
Old 02-09-2019, 10:01 AM   #32
stanski
Back of the pump
Old 02-09-2019, 04:01 PM   #33
GMC Guy
GMC Guy's Avatar
The one I used from Speedway is rated at 2gpm and I'd say it's about perfect, even with a 40 year old steering box.
Greg
1974 GMC
L33 5.3/4l65e
.................__
Copyright ©2000 - 2019, vBulletin Solutions Inc.
