Old 07-14-2017, 02:16 AM   #1
staydubbin
air line
where did you guys run your air line for your air ride? any pics or diagrams would be helpful. im running a full manual air ride set up
staydubbin is offline   Reply With Quote
Old 07-14-2017, 06:40 AM   #2
PGSigns
PGSigns's Avatar
Re: air line
I got all mine from my local Parker store. They had a very good selection of dot line and fittings.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-14-2017, 08:31 AM   #3
JohnJ@RideTech
JohnJ@RideTech's Avatar
Re: air line
As a rule of thumb, make sure you keep them away from moving parts and heat sources. I always tell people to make sure the line is properly secured to whatever you are mounting it to. Make sure that it wont move around and wear down the line.
In regards to heat sources; place your hand around the line and if your hand is close enough to something that may burn you, you need to move the line.
I hope this helps. Feel free to give me a shout directly if you need anything else.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 07-17-2017, 07:31 AM   #4
SCOTI
SCOTI's Avatar
Re: air line
True.
If reality forces no other options, slip some rubber hose over the airline & then some sort of heat shielding on top of that. Also, any place that the airline can contact metal, slip some rubber hose over it. Cheap insurance.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
