Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-21-2019, 12:24 PM   #1
davecarney2
davecarney2's Avatar
neutral safety switch question
So im finishing up my 6.0 LQ9 swap with 4L80E. Need help with the ignition switch on which terminals to use to wire the neutral safety switch.
-Lokar floor shifter has neutral safety switch built i.
-Generic ignition switch
-Ron Francis wire harness
pictures attached. Any help would be appreciated. Thank you in advanced.
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
http://67-72chevytrucks.com/vboard/s...d.php?t=592878
davecarney2 is offline   Reply With Quote
Old 09-26-2019, 10:10 AM   #2
Wrenchbender Ret
Re: neutral safety switch question
The sol term will go to the neutral switch & the other term. on the neutral switch goes to the starter selinoid.
George
Wrenchbender Ret is offline   Reply With Quote
Old 09-26-2019, 04:00 PM   #3
davecarney2
Thank you that’s what I was thinking was correct
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
