Old 07-06-2018, 03:20 PM   #1
tucsonjwt
Parking Brake Handle Install
Does anyone have any tips on replacing the parking brake handle? It is staked on the rod going to the parking brake assembly, and I am concerned that a replacement plastic handle will be broken if too much force is applied to attach it to the rod.
tucsonjwt is offline   Reply With Quote
Old 07-09-2018, 09:14 AM   #2
CSHADES
CSHADES's Avatar
Re: Parking Brake Handle Install
I haven't replaced one before but couldn't you heat the rod and then slide the plastic handle on?
CSHADES is offline   Reply With Quote
Old 07-10-2018, 06:02 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
I put the new handle in the sun and got it good and hot. pushed it right on. you could also put the rod in the freezer. what ever you do, make sure he handle is straight before you push it on all the way.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-10-2018, 03:36 PM   #4
tucsonjwt
Ok. I will try the sun trick - we have a lot of that here in the desert. Or, maybe a heat gun. The rod does have a very particular twist in it, so I will have to make sure that it is lined up correctly prior to installation. My old handle disintegrated like all plastic parts in the desert heat. Thanks.
Old 07-14-2018, 01:27 AM   #5
mikentosh
mikentosh's Avatar
All the replacement handles I’ve seen are threaded. In fact I just installed one on my new build a few days back. I took a #12-24 die to the rod to add some threads and it worked perfectly.
mikentosh is offline   Reply With Quote
Old 07-14-2018, 11:09 AM   #6
duallydude63
what yr ??? i m parting out a 81 & would B more then happy to give U the whole parking brake handle jst pay for shippin & its yours!!
duallydude63 is offline   Reply With Quote
Old 07-21-2018, 07:12 AM   #7
Pontiac1976
Pontiac1976's Avatar
A heat gun would work watch the heat do not use to much, slip it on do not to far.
To help with that mark the rod with masking tape how far the rod will go in so you do not push pass that point.
Then leave it till it cools give extra time before you try pulling the handle for the first time.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-21-2018, 10:34 AM   #8
tucsonjwt
I got a replacement handle from Classic Parts yesterday and it is a threaded handle. So, I guess I will have to try to use a #12-24 die to cut threads on the rod as mikentosh suggested.
