07-26-2017, 05:17 PM | #1 |
"88 GMC C2500 - ESC Module, issue?
My truck .. running fine, just coasting at 35mph, then , Service Engine Soon light / then ignition or ? stopped ... I thought the truck was going to die, then the light went out and truck ran fine. ( Took about 5 seconds)
The code eluded to the "just adjusted TPS".... and also the ESC ( Electronic Spark Control module)....... The ESC is interconnected to many components, like the TPS.... I am searching for a new ESC, just in case that's the problem, but anyone know of other parts that could also be connected to these parts? I am having a difficult time finding a new ESC....... Suggestions?
'70 GTO Midnight Blue '88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany. '93 Cadillac STS Black '93 Mercedes SL 500 Teal '86 Yamaha FZ750 - 15,000 RPM '86 Yamaha FJ1200 - Criminally Fast 2016 Ferrari 488 GTB, I drive it - don't own it. '05 GMC Yukon XL , SLT 4wd ( just purchased 2018) |
07-27-2017, 07:21 PM | #2 |
Re: "88 GMC C2500 - ESC Module, issue?
Maybe I over described my question....
The trouble code for this problem involves the TPS & ESC, but other parts will also set the same code. What other components would there be?
07-27-2017, 10:56 PM | #3 |
Which transmission does the truck have?
Which engine does the truck have? What code or codes did it set? How did you retrieve the code / codes?
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
07-28-2017, 06:50 AM | #4 | |
I think, #22 ( TPS low signal) but signal not low.... also mentioned ESC module. Code checker was a Snap On.
07-28-2017, 08:56 PM | #5 |
Code 22 does not have anything to do with the ESC
First thing is to check and see what code is in the memory. Use a link below if you do not know how to read the codes without a scan tool. http://www.chevytalk.org/fusionbb/sh...php?tid/273660 http://67-72chevytrucks.com/vboard/s...5&postcount=11 Then clear the code. Verify the code is cleared. Drive the vehicle and see if the code returns. Code 22 can be set by a bad TPS or a poor connection to the TPS. Have you moved the throttle stop screw?
07-29-2017, 08:14 AM | #6 |
The TPS is good / adjusted on the high side. The ESC also showed problems, as per a Snap On code reader. There's about 5 components that can affect the code.
( code was cleared)..... The truck lost ignition for 5 seconds, causing the code, but a TSP will not create that symptom. An OBD 1 system is like a house. A code will tell you what room in the house is in defect, but sometimes it WON'T tell you what, "in the room is bad".... ( I do not see a OBD1 code specifically for an Electronic Spark Control module) ....unless it is described differently in the list? ( I appreciate the ideas..... just trying to solve this)
07-29-2017, 10:26 AM | #7 | |||||
