Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-14-2016, 06:07 PM   #201
Stokester
Re: Hydroboost Mounting Plates
Got my bracket in today. Fast shipping and great packaging. BTW bracket fits 94 Astro Hydroboost in a 72 blazer! perfect! Thx captain!!!!
72 blazer 4x4 4" 35's
02 f150 work truck
15 f350 super crew long bed 6.7 4x4(stock but loaded)
02 f350 horse hauler 7.3 (need to sell)
Stokester is offline   Reply With Quote
Old 09-14-2016, 11:45 PM   #202
Captainfab
60-66 Nut
Thanks for the good words.
Just to be clear. What you bought is not a hydroboost mounting plate. You decided you did not want one. What you bought is a '67-'72 booster bracket.
Old 12-25-2016, 11:32 AM   #203
Possmguts
Possmguts's Avatar
Forgot to post when I got the mounting hardware a while back... But it fits real nice and is very nice quality. Thank You!
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-27-2016, 01:19 AM   #204
Captainfab
60-66 Nut
Thanks for posting pics of your installation.....looks good. Would you mind posting some info on the hydroboost and master you purchased? I know that the proportioning valve is the Wilwood 260-11179.
Old 01-16-2017, 10:03 AM   #205
Possmguts
Possmguts's Avatar
Thanks... yeah it was all bought as a Wilwood kit on ebay. The plate that comes on it lined right up with the mounting bracket I got from you. Worked like a dream. Didn't have to do anything but bolt it all up.
Old 03-20-2017, 06:39 PM   #206
boynton
boynton's Avatar
Originally Posted by burnitg View Post
CaptainFab:
What is your price for the direct mount plate, in bare steel, like the one you made for Curtb1971?
Thanks,
Burnett
I would like the same bracket but with mounting holes and black powder coat will be paired with a 2012 2500 Silverado unit.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 03-20-2017, 11:23 PM   #207
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Old 03-20-2017, 11:27 PM   #208
SunSoaked
CaptainFab-
I got an 85 K20 that I'm converting to a manual trans & hydro-boost. I'm having a hell of a time finding a pedal assembly for such that doesn't cost a fortune. Locating a manual/vacuum version seems to be much easier (and cheaper!). So, I'm thinking I'll first convert it to manual clutch/vacuum (its currently auto/vacuum) and then use your bracket to convert it over to hydroboost.
Am I understanding this right? You have a bracket that properly re-positions the hydro-boost unit to replace the vacuum unit? Does this correct the geometry difference in the pin height on the brake pedal? Any mods needed to the pushrod?
Thank you in advance,
Mike
"I once saw a six foot chicken eating prairie dogs like they were worms, but this was while driving between Janos, Chihuahua, Mexico and Agua Prieta, Sonora, Mexico on Route 9, after having consumed my share of El Presidente whiskey "
SunSoaked is offline   Reply With Quote
Old 03-20-2017, 11:35 PM   #209
Captainfab
60-66 Nut
I do not make any booster brackets or hydroboost mounts for the square bodies. There is no need since factory components are readily available. I do not know what the hole pattern would be if the factory booster brackets were removed from the vacuum booster. Those are riveted to the booster.
Originally Posted by SunSoaked View Post
CaptainFab-
Mike
Old 03-21-2017, 12:47 AM   #210
boynton
boynton's Avatar
This is what I am looking for. Plate with 5 holes, booster hole and four mounting holes. It will be used in a 72 k5
1970 SWB Step-Side
Old 07-05-2017, 12:50 AM   #211
Hidesertchevy
Are these still available?
Hidesertchevy is offline   Reply With Quote
Old 07-05-2017, 11:17 PM   #212
Captainfab
60-66 Nut
I fabricate all of my products everyday. Exactly which item are you asking about?
Old 07-06-2017, 12:15 AM   #213
Hidesertchevy
The hydro boost plate that mounts to the firewall in pic above this post
Old 07-06-2017, 11:37 PM   #214
Captainfab
60-66 Nut
That is not a regular production part. It was a special order for member Curtb1971. At the time I had a couple extra laser cut but I do not know if I have any left. I will have to look when I get top the shop tomorrow. You do realize that with this style you will have to open up the center hole to accommodate the nut on the hydroboost? Also this style does not lend itself very well to moving the pushrod attachment point on the pedal down 1"
Old 07-24-2017, 07:14 PM   #215
Harpie
Harpie's Avatar
Pm sent for purchase of a bracket sir. Thanks!
Harpie is offline   Reply With Quote
Old 07-24-2017, 11:10 PM   #216
Captainfab
60-66 Nut
I replied to your PM from this morning.
Old 09-09-2017, 05:09 PM   #217
upyourkia
PM Sent to Captainfab
upyourkia is offline   Reply With Quote
Old 09-09-2017, 10:59 PM   #218
Captainfab
60-66 Nut
I replied to your PM.
Old 09-10-2017, 05:33 PM   #219
78f1hundo
PM sent
65' Chevy C-10 Shortbox
78f1hundo is offline   Reply With Quote
Old 09-10-2017, 05:55 PM   #220
solidaxel
solidaxel's Avatar
Do you know what "size" the nut is for the H B unit?
Where can I find a new one ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll ZZ4 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red 327
340hp 4spd 3:36
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wifes cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-10-2017, 11:13 PM   #221
Captainfab
60-66 Nut
Are you talking about the large nut that secures the HB unit to the mounting plate?
Old 09-11-2017, 08:42 AM   #222
solidaxel
solidaxel's Avatar
Yes, what thread size is the nut?
340hp 4spd 3:36
Old 09-11-2017, 11:13 PM   #223
Captainfab
60-66 Nut
I really don't know and I forgot to take a look at one today. I do not think it is a standard thread pitch. The factory nut is 4 sided and is thin.
Old 09-16-2017, 06:02 PM   #224
Clyde65
Clyde65's Avatar
Pm sent for bracket, 64 c20
Clyde65
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is online now   Reply With Quote
Old 09-16-2017, 10:56 PM   #225
Captainfab
60-66 Nut
Copyright ©2000 - 2018, vBulletin Solutions Inc.
