Old 01-10-2019, 09:46 AM   #26
Mike C
Mike C's Avatar
Re: Trans and motor not listed on spid
Half ton 307 with standard 4 speed is unlikely as their are LOTS of 71 GMC with unmarked SPID for engine and trans but to our knowledge only 1 (yours!) seems to have a 4 speed.
Very unusual because it looks like a factory high hump floor which would not have been the case with the 3 speed.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-10-2019, 03:49 PM   #27
71gmcC15
71gmcC15's Avatar
So the spid could be wrong.
71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
71gmcC15 is offline   Reply With Quote
Old 01-10-2019, 08:53 PM   #28
Mike C
Mike C's Avatar
That seems most likely that whoever was typing it up just missed it.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-10-2019, 09:09 PM   #29
71gmcC15
71gmcC15's Avatar
I did some research on spid errors and from what I can tell you is no one typed the spids. They used the some kind of machines to type them and distribute them for people to put on the trucks. Not shure on all the details. I can tell you there was not a person typing the spids. Errors still could happen though. Like turbo hydra matic would be spelt wrong or something like that. Here's a link to the one I read.
http://67-72chevytrucks.com/vboard/s...d.php?t=647287
Old 01-10-2019, 09:50 PM   #30
Mike C
Mike C's Avatar
Someone still typed the info into something at some point, even if the SPID was printed in a batch. Human error is what makes the most sense. But the order was processed at some point to put the 4 speed in so somewhere there was a correct work order.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-10-2019, 10:23 PM   #31
71gmcC15
71gmcC15's Avatar
Ya I gess thats true. But if my spid is missing the 4 speed then other must be missing it to right? If they whare printed in large baches. Others would have the same mistake. At least that's what I would think.
Old 01-10-2019, 10:46 PM   #32
Steeveedee
Steeveedee's Avatar
Yup, I have a truck assembled in Fremont with the "u" instead of the "i" in turbohydramatic.
'70 Chevy 3/4T Longhorn CST 400/400/3.54 Custom Camper
"Orange Acres"
Old 01-11-2019, 08:49 AM   #33
Mike C
Mike C's Avatar
I think you are trying to apply how things work now to how things worked then. There was no database, no computer, no repository for all of the information that you are used to now. It wasn’t saved somewhere. It was inputted and outputted and used.
Like your own post right above where you left the T out of “batches”, someone working fast missed it on whatever invoice or documentation they used. They must have had some sort of double check to make sure the truck matched the order form but they chose (or missed) to ignore the SPID error.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-11-2019, 04:53 PM   #34
71gmcC15
71gmcC15's Avatar
It's hard to say what relly happened. And how the spid where made exactly. We got an idea but that's about it. Or at least I don't know all about it.
As for my spelling I'm pritty bad at it. I never past a spelling test. Ever. If it wasn't for auto correct.
So to compare my mistake to the spids mistakes is not a good one.
Any way it's a safe bet to say my spid has an error.
How it got? Don't relly matter in the grand scheme of things.
Old 01-11-2019, 06:24 PM   #35
RichardJ
I think the H05, 3.73 gears, triggered the 4-speed with the 307.
RichardJ is offline   Reply With Quote
Old 01-11-2019, 06:55 PM   #36
Mike C
Mike C's Avatar
That makes reasonable sense. If they 4 speed was packaged with the HO5 it wouldn't have to be on the SPID. And no error.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-12-2019, 11:59 PM   #37
I have never seen an option left off a SPID. I have seen the hump changed when a 4spd was swapped in. Quite a mystery. Normally the different ratio isn't listed and transmission option is. That is the fixed format.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi..........'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72' (rolling)
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 01-13-2019, 03:27 PM   #38
71gmcC15
71gmcC15's Avatar
So the h05 should not be on the spid?
Copyright ©2000 - 2019, vBulletin Solutions Inc.
