Old 01-11-2019, 10:02 PM   #1
Tripmiester
Active Member
Tripmiester's Avatar
Tilt steering column VS my stock one Help
I have this tilt column I bought from a friend, looking for some help to see if there are parts missing. My stock one that is non tilit has the stops for park ect.
Is this a aftermarket or a different year?
Any advise or experience would be much appreciated
Steve
Tripmiester is offline   Reply With Quote
Old 01-11-2019, 10:03 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Tilt steering column VS my stock one Help
Nothing missing, that new tilt looks ready to bolt in.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
Old 01-11-2019, 10:33 PM   #3
Tripmiester
Active Member
What keeps you from shifting from reverse into drive?
That is the part that is confusing to me.
My stock one has the little tit that falls into the bracket
on the end of the column.
It also keeps it in locked in park after shifting into park.
You have to pull the shift lever towards you to shift out of park
and from reverse into drive.
Thanks!
Old 01-11-2019, 11:55 PM   #4
Sheepdip
Sheepdip's Avatar
Your new tilt column relies on the transmission detent to pop into and hold in a certain gear.
Why these old stockers had those slots to lock into was probably more of a safety feature, you had to actually pull the shifter toward you to go from say N to R, D to R etc.
Could have been an idiot or a child proof effort...…. or both.
Sheepdip is offline   Reply With Quote
Old 01-12-2019, 10:19 AM   #5
Shinysideup
Shinysideup's Avatar
You have my interest. Ive never seen that lockout piece on 67-72 trucks.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is online now   Reply With Quote
Old 01-12-2019, 10:28 AM   #6
70shortfleet
70shortfleet's Avatar
The non tilt column has the detent at the bottom of the column as shown in the 1st picture and the automatic tilt column has the detent at the top inside the column at the shift lever, hope this helps, Les
70shortfleet is offline   Reply With Quote
Old 01-12-2019, 10:32 AM   #7
Shinysideup
Thanks Les, I was also concerned something was missing. Good to know the difference.
Btw, I almost bought a tilt at the local swap meet for $125 but the lower shaft was about 10" long instead of 3". Guy said it was out of a hot rod so no idea where it came from. The shifter lever seemed smaller too.
._____________
Old 01-12-2019, 10:34 AM   #8
Tripmiester
Active Member
Here are a few more pics,
This truck I am working on is a 1970 C-20 custom it has been all stock.
A real joy to work on, I thought they all came that way?
Old 01-12-2019, 10:50 AM   #9
72c20customcamper
72c20customcamper's Avatar
My 72 non tilt is like the first picture. Took a lot of adjustments to get the indicator to line up. Mines a 20 also
Mark
72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark
1969 AMX ,02 Springer. 03 anniversary Fatboy.
81 Honda automatic 1600 miles
2012 Road Glide Ultra 2015 Honda Goldwing
1968 c20 stepside 1977 Suburban
Old 01-12-2019, 11:38 AM   #10
Andy4639
Orignal Goof member
Andy4639's Avatar
Question Re: Tilt steering column VS my stock one Help
My dad's 56 Bel Air non tilt auto looks just like the first one also. I've never looked at a truck auto to tell. They look the same though!
Tripmiester,
question for you. Have you had trouble with you column in the truck not wanting to come out of park? My dad has been complaining about the 56 not wanting to come out of park and feels like it's going to break something. The only thing I can figure to do is bend those tabs back a little to make it easier to get out of Park. I've greased the tits up and that helped a little but man that thing is hard.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-12-2019, 12:17 PM   #11
Tripmiester
Active Member
Mine was pretty smooth coming out of park,
I have to pull the shift lever towards me to disengage from park.
Same thing from reverse to drive.
Old 01-12-2019, 12:26 PM   #12
Tripmiester
Active Member
Les,
Thanks for that info I feel much more confident installing the tilt one now.
Is it the same as the non tilt as far as pulling the shift lever slightly back towards the driver? Will it lock in park, and lock in reverse so you donít accidentally shift into either of those gears by moving the shift lever to far while in reverse, or while in drive into reverse?
Thanks again!
Old 01-12-2019, 01:46 PM   #13
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Tilt steering column VS my stock one Help
Thanks,
dad's feels like your going to break the dang shifter off when you come out of park. The indent plate on the 56 is held on with 2 screws. I'm going to pull it off and bend it just enough to make it easy for him. He is 94.
Yea pulling it toward you is the indent that keeps it out of reverse and park.
Old 01-12-2019, 02:12 PM   #14
Tripmiester
Active Member
94.......
He is my idle drive on DAD!!!!
Old 01-12-2019, 02:46 PM   #15
rjs53
They all or most all, depend on the column when shifting out of park. You pull in on the shifter to get it out of park. Its like a safety latch. Mine when I got it had been almost broke off cause they wouldn't pull in.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 01-12-2019, 05:57 PM   #16
Andy4639
Orignal Goof member
Andy4639's Avatar
Talking Re: Tilt steering column VS my stock one Help
94.......
Yea he still driving but it's scary to for all of us.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
