11-05-2018, 09:01 AM | #1 |
What Headlight Switch??
I have 1959 Apache Fleetside that I am upgrading to H4 Bulbs with the Relay harness mod.
What light switch do you guys recommend. This is what the truck has in it now and it's a POS.. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Any advice would be much appreciated. thanks. |
11-05-2018, 09:55 AM | #2 |
Re: What Headlight Switch??
I should have said that the truck has been rewired with a EZ wire 21 standard wiring harness.
11-05-2018, 09:13 PM | #3 |
Old member
As long as the lights have the fuses and relays ran and the whole system is wired correctly then that switch will do the job. I would have thought though it would have a factory wiring harness though.I have used the same switch on many golf carts and never had any problems with them.If your using the relays and the switch is just a on/off for the relay your fine.
