07-13-2019, 11:30 PM | #1 |
Pinned rocker stud
How do you remove a pinned rocker stud on a SBC head.. The rocker stud is cross threaded and needs to be removed..
07-14-2019, 01:38 PM | #2 |
Re: Pinned rocker stud
https://www.youtube.com/watch?v=WCkf95HpGs4
If your threads are totally stripped I think I'd start by welding something on to be able to pull it out. As a last resort drill it out and tap for a new stud. It might be best left for a machine shop to have it done right. What do you mean by pinned? Maybe I am missing something here as I am a newbie to the SBC. |
07-14-2019, 01:45 PM | #3 |
older sbc heads had pressed in rocker studs . sometimes they would start to pull up and out . the trick was hammer it back in . cross drill a hole and insert a roll pin to lock it in place .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-14-2019, 11:12 PM | #4 |
60-66 Nut
You will have to drive out the roll pin and then pull the damaged stud. Depending on the stud, this may require pulling the head unfortunately.
07-16-2019, 12:05 PM | #5 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-16-2019, 05:42 PM | #6 | |
They didn't drill it all the way through only50% so I can not drive the roll pin out.. Last edited by hjewell2; 07-16-2019 at 05:52 PM. Reason: mis print |
07-16-2019, 06:00 PM | #7 | |
driving is in my blood
Thats some half ass stuff right there. I'd drill the pin out, and keep going till its a full hole and not a half.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-16-2019, 06:32 PM | #8 |
[QUOTE=hjewell2;8559782]They didn't drill it all the way through only50% so I can not drive the roll pin out..[/QUOT
That’s the cheap method! Done that way 90% of the time. Can’t drill it out though. The pin is likely hardened. |
07-16-2019, 06:44 PM | #9 |
time to bump the performance up and fix the problem with new heads .
07-16-2019, 07:51 PM | #10 | |
Someone took the time to port the heads also. I know gm made tons of 76cc heads but these are big valve and good thick casting |
07-16-2019, 07:59 PM | #11 |
o.k. maybe worth a shop taking the time to fix them and swap to screw in studs and guide plates .
07-17-2019, 12:13 PM | #12 | ||
Yep... those can be modified to accept screw in studs.
Gary
07-17-2019, 03:29 PM | #13 |
If you pull the heads the machine shop should be able to drill through on the backside so the pin can be pushed out.
I'm talking out my a** a bit here since I've never done it but just my .02 Please let us know what you end up doing. |
07-17-2019, 06:16 PM | #14 | |
and guides. They said I"am the last person in Michigan to save the cast heads.. |
07-17-2019, 07:46 PM | #15 |
well you also know what this combo does and how it works so why not leave it alone and fix this goof and be done with no extra re-tuning / tweeking / pulling what hair you have out getting a whole new combo to run .
07-21-2019, 03:21 AM | #16 | |
The Shop I use says the same thing. I think they did some good work, I have not brought anything back to them! Most likely the Cast heads are still out there performing once they get hardened seats, viton seals and the other problems addressed. |
