Old 09-04-2005, 09:57 AM   #26
ckhd
ckhd's Avatar
Livrat --
Would you post a pic of that switch on the dash for me? I have a hole drilled over there and wonder if it's in the same spot. Right now, the hole has my torque converter lockup switch.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-13-2016, 01:09 AM   #27
rod1701
rod1701's Avatar
Re: Big Gas Tank
Originally Posted by Beast388 View Post
I have one of the large "through the wood" tanks on my '71 Burb. It holds about 45 gallons.
I have a few pics on my work hard drive that sorta show it.
Same setup on my 2WD 70 big block Suburban.
Is the fuel sending unit the same as factory replacement? I seem to be having vapor lock, and performance issues when it reaches operating temp. Starting through the fuel.system now to see where the problem may be.
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 11-13-2016, 02:12 PM   #28
WannaBe68
WannaBe68's Avatar
Re: Big Gas Tank
Guy I bought my 69 from this past summer, said this was a "40 gallon factory add-on".
WannaBe68 is offline   Reply With Quote
Old 11-13-2016, 02:30 PM   #29
Bigdav160
Bigdav160's Avatar
Re: Big Gas Tank
Those were quite popular. I had one also.
The sending unit looks just like an aftermarket universal with five bolt hole flange.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
