03-17-2021, 05:50 PM | #1 |
Hole for cowl damper (A/C)
The body shop gave me some new cowl sheet metal and I need to drill the front hole for my A/C fresh air damper. Would someone be able to measure their A/C pickup's firewall and tell me where I should drill this hole? I only need to find the front hole (towards engine bay), not the rear hole (toward pass. compartment). See arrow in attached pic. Thanks in advance.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
03-19-2021, 06:44 PM | #2 |
Re: Hole for cowl damper (A/C)
To be clear, the pic above is not mine, but shows the hole I need to drill. If you’re in your garage this weekend with a tape measure close at hand, I’d appreciate it!
03-19-2021, 08:46 PM | #3 |
I measured 1" from edge to center of the big hole in first pic.
Then 8.25" from edge to center in second pic. Let me know if you need a different reference point. |
03-19-2021, 10:37 PM | #4 |
That’s perfect, thank you!
03-20-2021, 01:01 PM | #5 |
IF we're in the garage! Good one!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
