Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Misc. For Sale
Old 09-15-2019, 09:18 AM   #1
68 TT
Still plays with trucks
68 TT's Avatar
complete big block Chevy water pump & alternator setup
This is the complete accessory drive assembly that bolts to the front of the engine including the water pump & pulley, crank pulley, alternator brackets & alternator and V-belt to run the water pump and alternator along with all new grade-8 mounting hardware. It also comes with a complete electric water pump drive assembly and the V-belt to run just the alternator off the crank pulley.
Complete low mount alternator setup designed to clear first gen Camaro or 1968-74 Nova subframe when running a big block with manual steering so it should also fit a 1970-81 Camaro. Also fits 1967-72 and 1973-87 Chevy trucks with manual steering. Tucks in tight enough to work on a dragster as well. Only selling because I am converting my drag car into a street car for my daughter.
Edelbrock 8850 Victor series aluminum short water pump, Moroso 64210 aluminum 25% underdrive crank pulley, GM 7" first gen Camaro water pump pulley, custom machined billet steel low mount alternator brackets with all new grade-8 fasteners designed to tuck a GM CS-130 series 105-amp alternator up out of the way of the Camaro frame rails and the center subframe crossmember that passes under the crank pulley. Comes with AC Delco reman 105-amp CS-130 alternator and belt to match along with new grade-8 water pump mount bolts and water pump mount gaskets.
Setup is also designed to easily swap over to the included Moroso 63750 electric water pump drive setup that is equipped with the optional 14-tooth overdrive pulley. Belt to match is included as well as new matching electrical connector shielded crimp on terminal to plug into power wire of drive motor.
Electric drive motor can be left in place with belt driven water pump pulley installed so only the water pump pulley swap is needed to make the change over any time you choose to do so.
Well over $800 in parts new. Asking $420 o.b.o. local pickup or $450 shipped USPS priority mail.
Mike
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-15-2019, 09:23 AM   #2
68 TT
68 TT's Avatar
Re: complete big block Chevy water pump & alternator setup
Pictures of the setup with the electric water pump drive installed.
