05-13-2017, 02:20 PM | #26 |
Re: Checking Driveling Vibration & Calculating It.
Looking at these Numbers - allows - No Pinion Wrap Up . .
1. Eng. Trans . 3 Degrees Down ( Correction ) 3.3 Degrees Down ! 2. 1st Drive Shaft Driven - Trig. Out the Angle to be 4.854 Degrees . 3. 2 sec. Drive Shaft Driven Trig. Angle to be 3.75 4. Rear Diff. Total = 3 Degrees Down. Equals Operating Angles of : Operating Angles of : 1st 1.55 2nd 1.1 3rd .75 Then Also : *Taking into Acct. say 1 Degree ( Wrap Up ) for 1 ton Springs* Looks like a Need to move Pinion at Least 1.0 Degree Down in Front . . Or Add 1 Degree Shim to the ( Leaf Spring Perch ) - making Total Pinion = 2.0 Degrees Down But the Operating Angle of 1.75 Degrees . . Running down Road - I'd get . . 1st Operating 1.55 2nd Operating 1.10 3rd. Angle 1.25 Degree - which would allow approx .65 Degree Wrap Up .. Operating Angle of 1.75 Degrees Hope I have this Sorted Out Now - Anyone Say ? Corrected Type -O Last edited by Port&PolishMan; 05-14-2017 at 12:19 AM. |
05-14-2017, 04:35 PM | #27 |
An another Easy Step is Checking Phasing of the Joints & Slip Yokes ..
Made Even Easier with Smart Apps for all Your Smart Phonies . `\ : - ) Like : Inclinator Pro $2.99 . . |
05-15-2017, 07:38 AM | #28 | ||||
And can you also remind me what the original complaint was (ie, bad vibration at speed)? Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-16-2017, 06:58 AM | #29 |
1954 1 Ton - has - Hoist , Stake _Dump - Dual
Mostly used for Grain & Feed - 50 yrs. Not suppose to be much _ Over All Mileage on it .. ? The Inclinator was used to double check Results , there were Small Variations ,( My Garage isn't Level with the World . ) LOL - just Kidding . . so Checked ..again and Found a Type - O in My Post . Yes, there are still Wheel Issues .. But just - Changing Rear Gear Oil made a Difference in Vibration .. - which looked like Sludge from a Sewer . Oh Joy ! Still there just - Not - as Crazy Amped - now it's just Big Time . * Angles Down as to Zero Point - V Cup = 1.25 Operating . . Vibration does seem ( Feel to It ) to be ( Twice the Speed of the Wheels ) See If I'm able to get You a Video . . Last edited by Port&PolishMan; 05-16-2017 at 07:15 AM. |
05-16-2017, 10:45 AM | #30 | ||
K
05-16-2017, 03:01 PM | #31 |
My Garage ..LOL - just Kidding .
After Topping Up the Rear - Gear , I Drained it and Flushed it some - Lighter Oil 30W - till it came out Much Cleaner , then Flushed with Fresh 80W90 - to Clear thew 30W - then Topped it up Full this Time . . Tried to Count the Vibrations - Compared to Second - leaning toward 10X Fast Vibration around @ 42 Mph - it feels like it's going 5X - 10X - The Wheels .. I should Test a New U-Joint , also .. Link show Movement & Sound . https://youtu.be/q-nLTHzsv8c Last edited by Port&PolishMan; 05-16-2017 at 03:12 PM. |
05-18-2017, 07:49 AM | #32 |
Checking U-Joint Caps - much easier with App .
Much _ Easier with Smart Apps for all Your Smart Phonies . `\ : - ) Like : Inclinator Pro $2.99 . . Another Very Good Source : https://www.youtube.com/watch?v=dAqAqODmcj4 |
05-18-2017, 08:44 AM | #33 | |
K
05-22-2017, 10:02 AM | #34 |
Yes, I'm Linking in Info to the Drive Line Thread , so it will be available in 1 Spot , sorta Speak .
Apps - are to anyone's Taste and there are Plenty ! I Happen to use the in Tn Orange - Apple Like this Link for Joints : http://www.therangerstation.com/Maga...08/ujoints.htm |
