Old 08-24-2017, 12:38 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question 3rd door window glass installation
Does anyone have any good tips/suggestions for installation of the 3rd door window glass? Just asking before I find out the hard way...... Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 08-24-2017, 03:14 PM   #2
HO455
HO455's Avatar
Re: 3rd door window glass installation
As per Leon I used Vaseline on the fixed window seals to make sure they seated all the way to the back. I installed the divider bar to check the glass was in the proper place. I had already set the moving glass in the bottom of the door but clear of the divider. Then when I was happy with the fixed glass I removed the fasteners from the divider and angled it forward and then fitted the sliding glass into the tracks and pushed the glass up and brought the divider back to its proper place and installed it. I should mention I had preinstalled new channel felts in the guides but not across the top. I cut and fit those last after the rest was done. I wrapped the divider bars in the middle with some thin plastic stock and taped it down to protect the paint on them. If I would have thought ahead more I wouldn't have taped the part that below the window frame as it was a real pain to get the tape off inside the door.
Just my 2 cents worth. Your results may vary.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
