Old 07-27-2020, 02:35 PM   #1
67C10Step
67C10Step's Avatar
Exhaust systems
Anybody buy a kit and do their own? I am starting to plan ahead past brakes, steering, and suspension. Exhaust is on the list. Right now I have a 2 into 1 with the muffler open right before the rear diff.
I'm torn on duals dumping right after the rear diff or taking both all the way to the rear. If I go to the rear I want to do something with both out one side. I don't want to go the normal two out the back route.
Photos of various systems would be appreciated. Step sides even better.
1967 C10
2020 Toyota 4Runner
2016 Toyota Corolla
2014 Toyota Highlander
2007 Toyota Tacoma
67C10Step is offline   Reply With Quote
Old 07-27-2020, 03:08 PM   #2
sick472
sick472's Avatar
Re: Exhaust systems
I can't help you with a kit, but I can tell you that my 85 K20 had headers and dual pipes with mufflers (thrush) that dumped under the bed right before the diff and it turned my bed into a speaker and vibrated horribly at the back glass. I had the pipes extended out the back and that helped tremendously. Whatever you do, take the tips out past the bed somewhere.
He who is without oil shall throw the first rod. Compressions 8.7:1
sick472 is offline   Reply With Quote
Old 07-27-2020, 03:39 PM   #3
fun in dirt
fun in dirt's Avatar
Re: Exhaust systems
Usually build our own. About to do another one next week & ordered this tube kit yesterday. Looks like it should cover everything (buying bend pieces separately gets expensive quick) https://www.summitracing.com/parts/sum-670146, we'll see when it gets here.
I have learned on these trucks that turn downs dumping before rear differential & sliding back glass will about choke you to death.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'01 2500 Suburban...party wagon
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'07 Classic 1500...DD
Built & sold cause can't keep 'em all:
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 07-27-2020, 03:45 PM   #4
70STOVEBOLT
Broke
70STOVEBOLT's Avatar
Re: Exhaust systems
I bought a Pypes 2.5 SS header back kit and modified it so I could tuck the exhaust between the frame rails. I have electric cutouts mounted under the tubular transmission mount and Thrush turbo mufflers mounted just behind the crossmember that the driveshaft passes through, and the tips exit behind the rear tires. It's pretty quiet in the cab unless the cutouts are open, but outside it's fairly loud, even with them shut. The truck has a mild 402, not a 250 anymore, I cannot change my signature for some reason.
70 SWB 250 TH400 "The Needy Beast"
200,000 Mile Club
Drum Brake Club
Daily Driver Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
70STOVEBOLT is offline   Reply With Quote
Old 07-27-2020, 04:17 PM   #5
68 P.O.S.
Slow Member
Re: Exhaust systems
Several companies make exhaust kits for these trucks. Off the top of my head there's Magnaflow, Thrush, Heartthrob, Pypes, Flowmaster, and Hooker.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-27-2020, 04:20 PM   #6
70cst
70cst's Avatar
Re: Exhaust systems
I have Spintech Mufflers ... they have a nice deep sound.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-27-2020, 05:52 PM   #7
67C10Step
67C10Step's Avatar
Re: Exhaust systems
In particular, I am looking for something that will mate up to the stock rams horn style exhaust manifolds. I want a rumble but don't care to shake windows and scare small children. I'll start poking around some.
1967 C10
2020 Toyota 4Runner
2016 Toyota Corolla
2007 Toyota Tacoma
Old 07-27-2020, 09:19 PM   #8
gmc684x4
Re: Exhaust systems
I see lmc has a magnaflo kit for 67 72 trucks
I ran magnaflo on my last camaro nice tone and was a true bolt in affair
gmc684x4 is offline   Reply With Quote
Old 07-28-2020, 08:39 AM   #9
Mts67C10K20
Active Member
Mts67C10K20's Avatar
Re: Exhaust systems
I am using the Heartthrob 2 1/4 system with hush thrush mufflers on my 67 K20
Have it 3/4 installed right now
Fits very well
Nice tone but can hear the radio
Mts67C10K20 is offline   Reply With Quote
Old 07-28-2020, 11:05 AM   #10
tdangle
tdangle's Avatar
Re: Exhaust systems
Is this a running truck? If so you may want to consider cost of the "kit" vs having a shop build one for you. I had a 2 1/2" dual system with a crossover and dynomax mufflers and chrome tips exiting out the rear done recently. No headers, using the stock ram manifolds. It cost me $650.
Terry
1970 Custom Camper/C20 , GM Crate 350/2004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-28-2020, 11:35 AM   #11
yellow&white72
I did my own exhaust. I bought a flow master ufit 3” stainless steel exhaust kit and magnaflow mufflers. I ran it all the way out the back and tucked them up behind the bumper and pointed them down so the tips aren’t really visible from the back. It was really nice kit made it pretty easy to install and had pieces leftover.
yellow&white72 is offline   Reply With Quote
Old 07-28-2020, 12:29 PM   #12
Jcfcamaro
Jcfcamaro's Avatar
Re: Exhaust systems
For what the kits cost I'd talk to a exhaust shop and have them do it. You could order your mufflers but make sure you get the inlet and outlet in the the right position. My buddy ordered a high dollar kit for his monte carlo with a cross over system and we had nothing but troubles with it. Ended up taking it to a shop and having a couple of the pipes bent a little more so it would fit the way he wanted. Make sure it's the last thing you do if your changing rims,tires , suspension ect.
Jcfcamaro is offline   Reply With Quote
Old 07-28-2020, 01:04 PM   #13
my67c20
Re: Exhaust systems
Bought the kit from LMC cause I needed a solution quickly. Easy to install, but was not happy with bends and look. Went to local shop and they tweaked it up for under $200. All in under $500. I see a few shops in your area like Pro Muffler and Exhaust, which does have a picture of a 67-72 in their gallery, so pretty sure you could get the system you want within your budget, especially if you provide a few of the bits. Also check out youtube if you want to get a rough idea of the sound.
my67c20 is offline   Reply With Quote
Old 07-28-2020, 01:22 PM   #14
siggyfreud
siggyfreud's Avatar
Re: Exhaust systems
Excuse the crappy photobucket watermark, I need to offload my old photos from that crappy site.
I did a custom dual setup on my 66. Ran them through the crossmember:
Then did a tailpipe that wrapped around the fuel tank. It was dual rears, but more centrally located.
Best of luck!
siggyfreud is offline   Reply With Quote
Old 08-01-2020, 02:25 PM   #15
Ben IV
Re: Exhaust systems
Just had mine done after my short bed conversion. I considered doing it myself with a kit but a local shop quoted me $500 with mufflers so I went that route. Figured the price of a kit plus mufflers plus down pipes for the stock manifolds I wasn't saving much money doing it myself.
70 GMC custom
69 GMC panel truck
Ben IV is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
