02-15-2017, 02:08 PM | #1 |
White or white cylinder heads
I was looking online for cylinder heads and white performance and skip white pop up. Are they one in the same or different? There is two different sites and they are both located in Kingsport Tn.. Is one company a rip off of the other?
02-15-2017, 02:37 PM | #2 | ||
"I ain't nobody, dork."
Re: White or white cylinder heads
Mostly just Chinese made knockoff parts. I'd avoid them like the plague... but some people like 'em.
Gary
02-15-2017, 03:46 PM | #3 |
Gary, what do you think of blue print cylinder heads? I'm looking cause the rpm cylinder heads I have crapped out on me after only 25,000 miles.. they are 6089 heads with the 170 cc intake runners. For the price the machine shop wants to do the heads over I'm better off buying new heads and who can beat the prices of these promaxx, blue print and etc heads...
02-19-2017, 10:35 PM | #4 |
What's wrong with the Performer RPM heads? Those and AFR used to be our go-to heads at a shop I worked at several years ago. I don't remember getting any complaints about them.
BTW, no way would I buy anything from the vendor you mentioned above.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-20-2017, 08:42 AM | #5 | |
Registered Truck Offender
What is it your machinist is saying is wrong with the RPM heads? Did you drop a valve and damage one, or ??????
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
02-21-2017, 10:20 AM | #6 |
The guides are bad. He says he replaces all the valves and the rest of the hardware when he does this job(450.00 a head).. I like the edelbrock heads but was looking for alittle more volume in the intake cc ports. Was also thinking of going with the blueprint 195cc heads cause that's will be readily available then the machine shop.. Any ideas on these?
02-21-2017, 03:59 PM | #7 |
Here's what I bought, http://www.jegs.com/i/JEGS-Performan...14032/10002/-1 Jeg's used to contract with Canton. I forget who they get them through now though.
02-21-2017, 08:16 PM | #8 |
unless there has been a valve job or 2 already done on the stainless valves, and unless the stems were horribly scored,,, I think you need a new head shop.
No the Edelbrock heads are not a AFR or Brodix, but at $900 to do a valve job??? your $200 from a new set of heads. I'll be happy to give you the $200 for them as is, sight unseen!
02-22-2017, 12:45 AM | #9 |
02-23-2017, 10:18 PM | #10 |
Ditto back at ya'.
03-05-2017, 09:22 PM | #11 |
X4!!
03-14-2017, 11:10 AM | #12 | |
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
