Old 04-18-2024, 11:18 AM   #1
57Suburb
57Suburb's Avatar
oddball waterpump outlet location
I installed an LSSimple accessory drive on my 6.0 swap, and in order to run their AC mount, it was suggested to install a 2012ish Camaro water pump which positions the outlet as shown in the photo. Anyone on here have this setup with a radiator inlet in the stock location (drivers side) and what hose set up did you go with. Thanks,
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 04-19-2024, 04:37 PM   #2
LS short box
Re: oddball waterpump outlet location
Not a truck swap but on my 73 LS3 swap I used "stock" style aluminum radiator. I struggled to find upper hose that fit. I ended up using two hoses and a splice. The splice also had a NPT opening for the head vent line.
I got splice from "Jaguars that run".
Lower hose I got from Oreillys by looking thru the selection in the back room.
Pic of the 73 upper hose.
Old 04-19-2024, 05:00 PM   #3
mongocanfly
mongocanfly's Avatar
Same here..I've had to do the hose splice on mine..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-20-2024, 09:24 AM   #4
57Suburb
57Suburb's Avatar
Yeah, I'm thinking I will need to do a split anyway because of the size difference between the inlet and outlet. Just wondered if there was an off the shelf hose the worked for a more "factory" look.
thanks for the reply
Old 04-22-2024, 01:16 PM   #5
mongocanfly
You can use the gates powergrip clamps (like heatshrink) instead of hose clamps to give it a cleaner look... ive got mine mocked up with hose clamps..but am using these once I get it all squared away..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2024, 01:29 PM   #6
57Suburb
57Suburb's Avatar
I came across this image, which shows what looks to be exactly what I'm wanting to do. Just got to find that hose.
Old 04-22-2024, 04:19 PM   #7
LS short box
Looking at the ECM maybe a Gen1 LS? Maybe a 6.0 in a 3/4 ton pick up. Or maybe a Denali? Or 6.0 in Escalade?
Old 04-24-2024, 09:04 PM   #8
jessemthompson
I believe that’s a Gates 24342 Premium Molded Coolant Hose. That’s what the square body guys use with the ls3 water pump. Idk if that’ll be a direct bolt on with th 67-72 though
jessemthompson is offline   Reply With Quote
Old 04-24-2024, 10:05 PM   #9
57Suburb
57Suburb's Avatar
This is one I’ve come across. Won’t know if it will work until chassis is back together.
