02-11-2019, 07:15 PM | #1 |
Is there any way to get wires through the A-pillar?
I'm doing a custom rewire, and want to avoid running wires across the floor, but the dome light is still needing power and ground.
My fall-back method will be to run the wires across the tranny hump, sleeved through a piece of metal oil line for protection. I'd like to get those wires up the inside of the A-pillar, but I'm assuming that's impossible. Can anyone give me a definite yes or no? |
02-11-2019, 07:19 PM | #2 |
Re: Is there any way to get wires through the A-pillar?
long fairly stiff length of wire like tig welding rod .
there is a spot under the dash were its open in the a-pillar . if you have 5-lights on the roof this is were the wire goes . so yes it can be done . also try puling the sun visor and maybe going down threw that hole and let gravity help . then its just back across the top is all . i just had my silverado apart and inside and the wires for the dome/speaker/cargo light all went along the carpet to door sill area and then up the b-pillar .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-11-2019, 07:40 PM | #3 |
Thanks for the info. I'll look into it. Fencing wire should work for threading through.
I don't plan to install carpet and door sills at this point. Maybe at some point in the future, but for now, bare metal is fine. |
02-11-2019, 08:49 PM | #4 |
I rethreaded the wire for the clearance lights in mine with string and a vacuum cleaner...
tied a heavy knot on the end of the string dropped the string in from the top stuck vacuum nozzle up to hole under dash sucked it right on thru
