03-11-2023, 04:37 PM | #1 |
Rear tail light and side marker wire routing
Does anyone have some pictures of the wire routing for the rear side marker lights and where to connect the ground wire.
03-11-2023, 08:12 PM | #2 | |
Re: Rear tail light and side marker wire routing
The rear lamps harness plugs into the intermediate harness’ boot connector at the rear crossmember. • The rear lamp’s harness routes through a rubber grommet placed into the bed cross sill’s front wall adjacent the LH frame rail. Reference 55060-K for a grommet replacement option. • Both sides of the rear lamps harness route through the bed cross sill’s interior. • Each side of the replacement harness has an in-line clip that snaps into the bed cross sill’s interior front wall. The replacement harness also retains with four black plastic coated clips inserted into the bed cross sill’s interior front wall. The original harness didn’t have snap-on clips and required six of these retainers. • The marker lamp wires route through their respective hole in the bed cross sill’s side. The tail wires route through their respective hole in the bed cross sill’s ceiling.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-11-2023 at 11:45 PM. |
03-13-2023, 10:48 PM | #3 |
Thank you 😊
