Old 01-12-2017, 12:22 AM   #1
Temple of Torque
Driveshaft Loop install for 72 C10
Hi All. Just finished installing a driveshaft loop on my 72. I used 2 pieces of 1x2 steel channel to anchor the Lakewood driveshaft loop. I am running Tremec and it was located as per NHRA specs...no more than 6" from the centre of the front u-joint. It was mounted between the floor pan and the frame rails. I did need to notch the channel out to allow for clearance to eliminate any vibration coming through the frame.
Temple of Torque is offline   Reply With Quote
Old 01-12-2017, 07:45 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Driveshaft Loop install for 72 C10
Nice job! I will ask tho....is it a 1 or 2 pc shaft? My old longhorn is a 2 pc deal, & runs 2 hoops....1 , 6" from the front joint, & 1, 6" from the 2nd joint. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-12-2017, 10:43 PM   #3
Temple of Torque
It is a two piece driveshaft. The second loop is next.
Old 01-12-2017, 11:33 PM   #4
crazy longhorn
Good deal....on a side note, how do you like the TKO trans? Longhorn
