01-24-2018, 04:59 PM | #1 |
Rear Brake Line Routing
Ok guys, need a sanity check here. I am installing my rear Wilwoods and ready to run ss hard line back, then split out to braided hoses (flex) to calipers. I know the normal route is to flex down to rear end and run hard line out to either end of axle, then flex to calipers - but, is there any reason not to run hard line back along frame, then split directly across frame cross member, and then flex to calipers (from frame instead of axle tube? I think with a lot of travel this might be an issue, requiring a long braided line, but with coil overs and lowered, shouldn't be that much travel. Thoughts? Anyone done this, got pics?
Thanks, Jim |
01-24-2018, 07:28 PM | #2 |
Re: Rear Brake Line Routing
That is the way I did it . Best pic I have is in post 42 of my build thread. I am using ford explorer brake calipers with S10 (I think ) brake hoses . Brackets have not been added in this pic.
http://67-72chevytrucks.com/vboard/s...d.php?t=740665 |
01-24-2018, 11:31 PM | #3 |
That is a very common method of routing brake lines, especially when guys want to keep their rear ends clean (wait, that sounded wrong...). Do it.
01-25-2018, 10:51 AM | #4 |
Thanks guys!
01-26-2018, 07:46 PM | #5 |
Just one more to agree with all that's been said, that's how I ran mine
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
