Old 03-07-2018, 11:10 PM   #1
Jafo20
56 cab on its back
After I get my cab off can I lay it on its back? Back window down. It would make my job of cleaning it up easier. I just don’t damage the cab. Thanks
Jafo20 is offline   Reply With Quote
Old 03-07-2018, 11:22 PM   #2
MARTINSR
MARTINSR's Avatar
Re: 56 cab on its back
I plan on doing this too, I am going to make a cart out of 2/4's or 2/6's with a hinging mechanism to tilt it back. It will have wheels on it so I can put it up on the tow truck and then roll it off at the sand blasters so they can blast the floor underside and top and the firewall inside and out.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-07-2018, 11:27 PM   #3
mr48chev
mr48chev's Avatar
I've seen guys lay them over on an old mattress or maybe the cushions off an old couch. A couple large sheets of cardboard might be enough padding or maybe a couple of those HF furniture pads. Something to keep it from going directly on a hard surface.
My ongoing truck projects:
Old 03-08-2018, 12:04 AM   #4
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Ive seen guys use old futon mattresses or moving blinks and couch cushions.
GreasyLikeaBurger is offline   Reply With Quote
Old 03-08-2018, 12:26 AM   #5
vics stuff
I had built a body rotissory for my builds. Just to make it easy to access all the panels easily.
Vic
vics stuff is offline   Reply With Quote
Old 03-08-2018, 12:50 AM   #6
roger55
roger55's Avatar
Makes it easy to blast clean:
roger55 is offline   Reply With Quote
Old 03-08-2018, 01:12 AM   #7
Foot Stomper
Foot Stomper's Avatar
Thick dense foam worked fine.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 03-08-2018, 11:38 AM   #8
dsraven
some thick foam or an old mattress will probably work fine. there are a couple of high spots, one on each side at the outboard edges, that will hi the floor first so place thicker padding there. if you make a table, like roger55 did, you will likely want to make the table narrower than those high spots. if you look at roger's you can see that is how he did his. it will sit on that depressed area. a large surface area will give the best results because less pounds per square inch.
Old 03-08-2018, 12:45 PM   #9
SanJosesSteve
SanJosesSteve's Avatar
Damn that looks like fun..... Just out of curiosity, how many guys does it take to manhandle a stripped cab without getting hurt? I always assumed that the bed comes off first, then you lift the cab a few inches, slip some timbers underneath and walk it to the rear of the truck to clear the frame.
This is exactly what I want to do 6 months after writing the final college tuition check for the kids! Been a long time coming, but I see light at the end of the tunnel! -Steve
"What's that round short pedal on the floor do?"
SanJosesSteve is offline   Reply With Quote
Old 03-08-2018, 01:24 PM   #10
Daze57
Daze57's Avatar
a bunch of packing blankets stacked would work
Daze57 is offline   Reply With Quote
Old 03-08-2018, 03:06 PM   #11
_Ogre
_Ogre's Avatar
i rolled my cab on the back and front end a few times when working on the cab
makes it a lot easier to weld up floor supports and finish welding floor patches
shop air compressor timer
Old 03-10-2018, 11:33 PM   #12
roger55
roger55's Avatar
Originally Posted by SanJosesSteve View Post
Damn that looks like fun..... Just out of curiosity, how many guys does it take to manhandle a stripped cab without getting hurt? e
Just me.
Old 03-11-2018, 12:03 AM   #13
Dan in Pasadena
Dan in Pasadena's Avatar
Roger,
Pretty impressive that a single 2x took the load of the cab. Was it a very deep 2x, like a 2x12? Or maybe a prefabricated truss?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-11-2018, 12:16 AM   #14
roger55
roger55's Avatar
It's a 2X6. The cab is totally empty. Doesn't really weigh that much.
The eyebolt goes up into the attic and goes though another 2X6 placed across the top of two 2X6 joists. Used a big washer under the eyebolt nut. Believe me, it's way more than stout enough. I'm sure it would lift double that weight without a problem.
Old 03-11-2018, 01:16 AM   #15
mongocanfly
mongocanfly's Avatar
agreed^^^^ cab doesn't weigh much...I used a 2x4 when I pulled my AD cab yrs ago...just like Roger did...but outdoors..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-11-2018, 11:01 PM   #16
Atommik
Atommik's Avatar
I lust rolled mine (51 cab) on its back in the grass. No damage that I could see!
Atommik is offline   Reply With Quote
