Old 12-11-2018, 04:15 PM   #1
straight6chevyguy
straight6chevyguy's Avatar
Backup lights not working
I have a 1998 Chevrolet C1500 single cab long bed 4.3L v6 5speed Manual.
The backup lights have not worked since I got the truck a few months ago.
I have tested and there is NO voltage getting to the bulb sockets.
The Fuse IS good.
I'm thinking its a switch or bad wire connection at the switch or some place.
some input would be appreciated.
straight6chevyguy is offline   Reply With Quote
Old 12-11-2018, 05:03 PM   #2
Mr_Rich
Mr_Rich's Avatar
Re: Backup lights not working
Two places to look; steering column or transmission. Look for a screw-in type unit on the trans with a plug connected to it. That's the likeliest culprit.
And I want to add it's much different than the VSS sensor.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 12-11-2018, 05:43 PM   #3
sweetk30
sweetk30's Avatar
stick shift switch pics of the 2 offered here so you can know what to look for .
https://www.rockauto.com/en/moreinfo...303344&jsn=476
https://www.rockauto.com/en/moreinfo...303344&jsn=477
hope these pics help you find it and check it . lots of times i have seen the plunger ball get gummed up and just need some brake cleaner to clean it out and work .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-11-2018, 08:02 PM   #4
straight6chevyguy
Thanks guys!
Tomorrow I will look at it if weather permits.
Old 12-12-2018, 10:38 AM   #5
sntrym95
sntrym95's Avatar
Check the wiring in the back too, especially if a towing harness has been spliced in.
Mike
sntrym95 is offline   Reply With Quote
Old 12-12-2018, 07:44 PM   #6
sweetk30
sweetk30's Avatar
forgot that one . but seen it a lot . even a aftermarket t-harness go bad and cause this .
Old 01-02-2019, 05:56 PM   #7
straight6chevyguy
I'ts been awhile but finally today I got the truck up on the ramps.
Getting power on one pin on the connector & when I jump the 2 pins the backup lights come on.
Well I guess it's the switch!
Thanks again guys!
I just have to figure out which of the 2 switches is mine & get it ordered.
I'll let you know when I get'em working.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
Old 09-04-2022, 02:57 PM   #8
straight6chevyguy
So a few years later Im looking at this thread I started and realize that I never updated this!
So what happened was I got a new switch but lights still did not work.
New switch tested good.
With switch wires hot wired lights worked.
With Switch wires connected to switch and switch not in transmission, holding the switch in my hand
I push the contact on the switch with my thumb, the lights worked.
So I came to the conclusion that whatever it is in the transmission that makes contact with the switch
Is either broken or wore out.
So at this point I just said the heck with it and wired the lights up to a toggle switch in the dash that was no longer used that had been installed by the P.O.
Been running it this way since.
I plan on rebuilding or replacing my transmission in the near future so I will try to get the factory switch setup working then and will post an update if I do.
To many projects!
Old 09-05-2022, 08:37 AM   #9
Thanks for the update. And now we know this can happen, which is really helpful
