Old 03-14-2015, 05:58 PM   #51
SIR
SIR
SIR's Avatar
Re: Lets see your gauges setups
hanline...look & work great....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 03-14-2015, 06:15 PM   #52
Mackie
Mackie's Avatar
Wish the pic was better SIR. I have a set of gauges in my OT VW Karmann Ghia from Haneline. They have nice stuff.
Mackie is offline   Reply With Quote
Old 03-14-2015, 06:59 PM   #53
weeniewawa
Originally Posted by Mjminino View Post
what if the gps has bad signal??
the only time you get a bad GPS signal is in long tunnels or otherwise underground. not sure how this accesses the satellites but a regular GPS uses about 12 of them at one time and if one is blocked by trees or mountains, the accuracy goes down a bit until it gets full visibility again to the sky.
these GPS speedos must have some sort of antenna that has to be mounted outside.
weeniewawa is offline   Reply With Quote
Old 03-14-2015, 08:52 PM   #54
Hugh in NC
Hugh in NC's Avatar
Originally Posted by gmcdeadhead View Post
Hugh in NC, what size are those autometer sport comp gauges ? and what's the thickness of that boise aluminum insert ? i am going to make my own inset and would like to no the thickness i could use. thanks
Here is the link to the insert that looks like the one I purchased. You tell them what brand and style of gauges you are using and they machine to fit.
http://www.boeseengineering.com/Shop...lphin-gauges-1
I really cannot remember the exact thickness but it was near .25 inch. Each of the gauge holes was counter bored (?) about .125 so that the gauges set down into the insert. If making your own, I do not think the thickness is critical as long as it is thick enough to prevent flex, gauges do not have to be recessed either. Small gauges are 2 1/16 diameter, large 3 3/8 inches. I ordered mine with the brushed finish.
Show us what you end up with when you finish.
Hugh
Hugh in NC is offline   Reply With Quote
Old 03-15-2015, 11:24 PM   #55
joedoh
joedoh's Avatar
Originally Posted by Mtrhd329 View Post
Heres mine. I had an old 94 z28 cluster laying around and i jeeded electric gauges with my 5.3l swap. Went together pretty easily
me too, but I left the original silkscreen on the lens
Old 03-15-2015, 11:57 PM   #56
Mtrhd329
Sneaky sneaky. That looks cool but it would drive me crazy trying to look through one set of numbers to see the other gauges. Pretty incognito if you just glance quickly
Mtrhd329 is offline   Reply With Quote
Old 03-16-2015, 11:05 AM   #57
earl84
Ooh, man, that would drive me crazy, but it does look kinda cool.
earl84 is offline   Reply With Quote
Old 03-16-2015, 07:16 PM   #59
Joe Pass
Joe Pass's Avatar
Looks right....
Joe Pass is offline   Reply With Quote
Old 03-16-2015, 07:25 PM   #60
LDO
LDO's Avatar
Originally Posted by theastronaut View Post
Nothing special, just a "factory" cluster.
You know, I'm not a 'mod-a-holic' but I do like to change things up a little. Your original guage cluster really looks great! I wonder if it could be changed so that the indicators would be actual numbers instead of 'tick-marks' and if the back lighting could be changed to red.....THEN, I'd be sold on it for my truck. I've got an autometer setup thinking that it was what I wanted but I'm not very happy with the look. Now I'm looking for something different!....again!
LDO is offline   Reply With Quote
Old 03-16-2015, 08:55 PM   #61
joedoh
joedoh's Avatar
honestly, you dont even notice it.
Old 03-16-2015, 10:06 PM   #62
Big Fenders
Mark..I haven't seen your cab/dash for awhile...really over the top!!
In other words..I like it
Bob
Big Fenders is offline   Reply With Quote
Old 03-17-2015, 09:41 AM   #63
lee64
Astronaut, really like that clean look. What all is involved in re-numbering/recalibrating the speedo?
Lee
lee64 is offline   Reply With Quote
Old 03-17-2015, 09:52 AM   #64
66LSx
66LSx's Avatar
one more...
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 03-17-2015, 10:08 AM   #65
theastronaut
theastronaut's Avatar
Lee
All I had to do was send payment, a lens, and a block off plate to Jason at Greenback Decal. He uses a stock block off plate for the face of the tach, and uses his own internals and overlay for the graphics. I wetsanded and buffed the lettering off a reproduction lens and he screen printed new numbers on the lens. He can do 6,7,8k tachs as well if you don't want or need a 10k tach.
The speedometer may end up being driven by an Abbot cable-x box or Dakota Digital's newer version. That will take car of the speedometer calibration. Jason handles the tach calibration.
theastronaut is offline   Reply With Quote
Old 05-17-2017, 07:45 PM   #66
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I posted this in another thread:
Originally Posted by LostMy65 View Post
I've been banging around this idea:
White led digital gauges I think would blend in nicely.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-30-2018, 11:17 PM   #67
forestb
forestb's Avatar
Did a little more work on my gauge cluster today. The little bow ties have chrome behind them and the bezel is going to be chrome.
forestb is offline   Reply With Quote
Old 07-06-2019, 08:30 PM   #68
forestb
forestb's Avatar
Got the gauges installed yesterday.
Old 07-06-2019, 10:09 PM   #69
TR65
TR65's Avatar
I got the Dakota Digital Retro gauges installed last week. All the readings are taken from the LS bus except oil pressure, they provided the pressure sensor.
There are multiple screens you can click thru on the left hand display and customize them as you wish. I converted the choke knob to a dimmer for the back light.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-08-2019, 10:50 AM   #70
chevy_mike
Never Ending Projects
chevy_mike's Avatar
TR
Nice setup!!!! I would have likely gone with that but when I got my Dakota Digital gauges, those were not made.
Here is mine.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-08-2019, 06:49 PM   #71
LostMy65
LostMy65's Avatar
Here is mine.
Are yours from a newer model truck?
Old 07-08-2019, 07:01 PM   #72
LostMy65
LostMy65's Avatar
Never mind, I found it in your thread :
http://67-72chevytrucks.com/vboard/s...77#post8500677
