07-23-2018, 08:38 PM | #1 |
Cruzin
Knocked off spoiler on top of burb nuts that hold it on?
Ok hit garage door with the spoiler on back of my 91 burb, it's held on with well nuts but the ones I got at lowes are to thick on top and can't get them to tighten in good. Are correct ones available? Or other options.thanks
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
07-24-2018, 10:15 AM | #2 |
Re: Knocked off spoiler on top of burb nuts that hold it on?
Can you cut the threads a little to shorten the bolt so it can screw down all the way? Be sure they are stainless steel.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
07-24-2018, 05:18 PM | #3 |
Thinking about the well nuts for a voltage regulator without seeing the spoiler ones
07-24-2018, 06:36 PM | #4 |
Cruzin
I didn't specify sorry, they make the spoiler sit off the body too much, the others were about thin as a washer. Also they just aren't pulling up good they start spinning messing up the rubber.
07-24-2018, 06:46 PM | #5 |
Cruzin
Here is what lowes had thick top. Found some thin top ones on amazon last nite and ordered, they have a GM part number in listing.
07-26-2018, 09:50 PM | #6 |
Cruzin
Update: got the ones I ordered from amazon in today. They fit great spoiler is mounted nice and tight, 5 min job. Just in case anyone needs them GM #528846 1/4 -20 well nuts.
07-26-2018, 10:51 PM | #7 |
Thanks for the link....just in case.
Romans 10:9 - The Truth |
