Old 04-24-2018, 07:56 AM   #1
70GMCer
70GMCer's Avatar
What are these 2 firewall things
Still trying to figure out, (among other things), the wiring on my 83.
Can someone tell me what was on the firewall in the outlined circles?
The one is some kind of harness that has been cut out...the blank area looks like maybe some type of relay was there.
70GMCer is offline   Reply With Quote
Old 04-24-2018, 09:29 AM   #2
JWall
Frequent Flyer
JWall's Avatar
Re: What are these 2 firewall things
The bottom one appears to be the hole for the heat & air conditioning wiring.
- Justin
1 Owner 1976 SWB
Old 04-24-2018, 09:38 AM   #3
85Misac10
I believe the top is a vacuum regulator and the bottom one is part of the engine harness
85Misac10 is offline   Reply With Quote
Old 04-24-2018, 09:42 AM   #4
85Misac10
It goes to the ecm under the dash.
Last edited by 85Misac10; 04-24-2018 at 09:44 AM. Reason: unable to post other urls
Old 04-24-2018, 02:18 PM   #5
70GMCer
70GMCer's Avatar
My AC harness looks to be complete. That's the harness in the picture between the 2 outlined circles.
I didn't think an 83 had a ECU. If it's there, it's behind the inside heater box and can't be seen & the truck runs normal.
Might it be the wiring for the cruise control system?
Old 04-24-2018, 03:01 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
The 83 had ESC (electronic spark control)from the factory. Most of them were trashed and a regular HEI distributor was installed.
If your trck had a 700R4, there was a TCC lock up solenoid mounted to the firewall.
95 S_Trucker is offline   Reply With Quote
Old 04-24-2018, 04:14 PM   #7
70GMCer
70GMCer's Avatar
Thanks......That does make since as the SPID says electronic spark control & it does have a HEI dist now.
Not sure about the 700 trans though as it has a 400 turbo in it.
Old 04-25-2018, 07:03 PM   #8
gezn2
Yup, that grommet is for the ESC harness and the bare spot above it is the vacuum sensor for it.
A 700R4 would use an identical-looking vacuum sensor on the drivers side firewall.
gezn2 is offline   Reply With Quote
Old 04-25-2018, 07:53 PM   #9
RyanNewberry
I know this isn’t my thread so I apologize but what’s it take to remove the esc harness? Just remove it and install a hei distributor or is there something I’m missing?
RyanNewberry is offline   Reply With Quote
