03-12-2018, 10:06 PM | #1 |
SM465 Issues (PLEASE HELP!!)
Hello Everyone,
Ok so I have a problem I was driving my k5 to work this morning and I came up on some slow moving traffic so when I had an opportunity to pass I downshifted to 3rd and got around the vehicle in a timely manner but when I went to shift back into 4th the shifter was stuck in gear. I was almost to work so I just cruised in 3rd. I've already pulled the shifter and tried lining up the shifter gates with a bar but it is stuck. I also pulled one of the PTO covers off and everything seems to be in place. I also tried removing the cover but I can't get the cover off without putting the tower part way into reverse which won't happen if it's in 3rd At least that I can think of. So to my question, is there any way to remove the shift tower with it jammed in gear? I honestly believe it's something with the shift tower detents.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
03-13-2018, 10:39 AM | #2 |
Re: SM465 Issues (PLEASE HELP!!)
If the problem is in the shift tower You should be able to move the gears to neutral & slide reverse gear halfway in. Do you have pressure off the drive shaft. Block the wheels & put the clutch in.
George |
03-13-2018, 02:31 PM | #3 |
I had the transfer case in neutral and the clutch in when trying to shift the tower and the rails are bound none will move but the trans rolls smooth no binding with the pedal pressed in and no obvious slop in the shafts
03-13-2018, 05:24 PM | #4 |
Ok so an update I was able to get the shift tower off. And it isn't stuck like I had originally thought the shift collar for 3rd & 4th gear is stuck on 3rd it's free floating but won't slide back to neutral
03-13-2018, 05:52 PM | #5 |
The towers are not hard to work on. Just watch for a little pin inside the rails. They fall out & get lost easily. There is a steel ball between each 2 rails. When one rail is shifted the ball pushes the pin & ball on the other side preventing the other rail from shifting into a gear. There are steel balls with a spring behind them above each rail. These balls pop into a groove in the rail giving it the detent effect. Often one of these springs are broken & the shifter will move easily with out any resistance from the detent.
If all that makes sense you are good. George |
03-13-2018, 05:55 PM | #6 | |
03-13-2018, 06:36 PM | #7 |
have you been having trouble with it falling out of 3rd gear ? if so you have a bad synchronizer I ran a 87 c30 rollback for over 400k and rite at each 100k they would need to be replaced .as with the front bearing also being replaced . it sounds like this may be your problem .
4x4k30 if trouble was money i would have plenty |
03-14-2018, 11:18 AM | #8 |
One of the First
NOVAK sells good rebuild kits if you get to that point.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
03-16-2018, 08:18 AM | #9 |
4x4k30 - No I've never had an issue with 3rd gear surprisingly
I actually pulled the trans already and am getting ready to order a full rebuild kit plus the updated 3rd gear parts
