Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-15-2017, 08:30 PM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Seam sealer removal and install question
Working on my 87 Silverado, with the motor out, decided to clean the firewall up. Noticed some rust colored runs in the center of the bulkhead seam above the trans tunnel. I removed the wiper cowl and screen and found the factory seam sealer started to deterioate. After picking at the seam seal material for a solid 30 plus minutes.. decided to surf the web for an easier way to dissolve the old seam sealer.
Some searching found say brake cleaner, gasoline, good off.. having tried either yet.
But, when I get it out.. what's the best way to get new seam sealer in there.. doubt there's no chance of getting the applicator gun in there... looking into the self leveling stuff since its the thinnest and would possibly get further in the joint. One idea I came up with is to squeeze out the mix into a syringe and then apply it...
Looking for advice from others that may have tackled this.
Thanks,
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-15-2017, 08:39 PM   #2
Lunnb
Re: Seam sealer removal and install question
I used a wire brush on a 4.5" grinder . Quick easy and took it to bare metal . I replaced with 3m seam sealer , smoothed with a finger moistened with mineral spirits .
Lunnb is offline   Reply With Quote
Old 07-15-2017, 09:00 PM   #3
87chevy.com
Did you use a brush on seam sealer, 1 or 2 part caulk tube type?
Old 07-15-2017, 09:09 PM   #4
Lunnb
I bought the single tube version on Amazon . It was easy to apply , similar to a stiff caulk. It did setup pretty quick but allowed time to dress it with the mineral spirits and finger . I did the entire drip rail of my 64 C10 with one tube if I remember correctly.
