Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-08-2017, 03:20 PM   #1
What's this relay for?
Hey y'all, trying to fix bad wiring PO had done with gauges and starter and everything, and came across this relay that is wired into the push to start button. Have no idea what it does, truck has driveline out of a 2000 Tahoe, so is it to bypass security or what? Thanks.
bbluma is offline   Reply With Quote
Old 08-08-2017, 10:09 PM   #2
Msgt USAF Ret
VetteVet's Avatar
Re: What's this relay for?
That looks like it might be a digital circuit breaker. normally opens at 40 amps and closes at 30 amps. Just a guess.
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-09-2017, 09:36 AM   #3
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: What's this relay for?
For what it's worth I did google it and it's pretty much what Vett said. For what it's use is in your truck It's hard to say. Trace the wires and see where they take you will be the only thing to know for sure. Are talk to the PO and see if they remember what they did.
Good luck.
1971 LWB Custom, 6.0LS & 4L80E, GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 1997-2013
