Old 08-11-2017, 11:12 PM   #1
Nima
Blue 67
Rebuilt heads and breaking in
Hi:
If The heads are rebuilt, does the engine needs to go through any breaking in process? If yes, what is that and how does it get done?, Any specific oil to use? I am reusing the original rocker arms and push rods, and heads are rebuild too stock specs, nothing wild. The engine is a 5.3 vortec.
1967 C20, 350 with 3 on tree, 2/14 dual exhaust. 4 wheel disc brake; finally done
2005 Silverado 2500, 4x4 Duramax, 4" MBRP exhaust,
1972 Nova (new project)4 door, 6 banger with powerglide tranny.
Nima is offline   Reply With Quote
Old 08-11-2017, 11:38 PM   #2
truckster
truckster's Avatar
Re: Rebuilt heads and breaking in
If you just did the heads you really don't need any type of break in.
I'm assuming you didn't replace the cam or lifters.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 08-11-2017, 11:45 PM   #3
Nima
Blue 67
Cam, lifter and everything else is the same.
Old 08-12-2017, 07:06 AM   #4
homemade87
There is no real reason to break heads in . If I have the heads off what I like to do is put it thru a full heat cycle so every thing will expand and seat it self in a full cool down and then hammer on it .
Even if I did a cam and lifter & spring change I would do the same . The cam and lifters are different form the old days .
homemade87 is offline   Reply With Quote
Old 08-12-2017, 08:20 AM   #5
truckdude239
truckdude239's Avatar
nope no breaking not even on the cam in those they are roller cams
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
1998 Honda Accord 4 door with 318k(brothers car)
Old 08-12-2017, 11:58 AM   #6
truckster
truckster's Avatar
Good catch. Sloppy reading on my part.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
