Old 03-27-2016, 07:11 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
How to clean exterior Evaporator Core
I'm asking...ha!......
Seems water, degreaser, a brush and blow dryer are the ticket, but I thought to ask before I do something I shouldn't. Thanks.
Tony
71 C10 Custom Deluxe, SWB, fleet, 402, A/C...Resource intensive
72 Cheyenne Super, LWB, fleet, C20, 402, A/C. Driver and tinker truck
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-27-2016, 08:56 PM   #2
F.A.A.benny
Re: How to clean exterior Evaporator Core
That's one way to do it
F.A.A.benny is offline   Reply With Quote
Old 03-27-2016, 11:42 PM   #3
SS Tim
SS Tim's Avatar
GM has a really great evaporator dip cleaner we used for problem cars that was not only a cleaner but a anti-growth protective coating as well. Try you local dealer for more current information and what it would cost you.
SS Tim is offline   Reply With Quote
Old 03-28-2016, 04:06 AM   #4
F.A.A.benny
The first thing I do is use compressed air to blow out as much of the crap in between the fins as possible.
Old 08-11-2017, 10:06 PM   #5
lugnuts09
What's the best method of cleaning this? Trying to overhaul the A.C system and replace the heater core.
lugnuts09 is offline   Reply With Quote
Old 08-11-2017, 10:55 PM   #6
HO455
HO455's Avatar
There are lots of coil cleaning products out there. Here is a list from Grainger.
https://www.grainger.com/category/co...leaner&sst=All
http://www.superiorperformancenw.com
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F1-3 Ford 4X4
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 08-12-2017, 08:30 AM   #7
Bigdav160
Bigdav160's Avatar
When I see an oily spot, like on the upper right corner of Lugnuts evaporator, I think "leak".
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is online now   Reply With Quote
Old 08-12-2017, 10:49 AM   #8
lugnuts09
I've never really worked on an a.c. system before. It hasn't been hooked up since before I bought the truck. They even bypassed the heater core. I sure hope it's not a leak. All of your input is greatly appreciated.
Old 08-12-2017, 05:24 PM   #9
F.A.A.benny
It should flushed and pressure tested. I would not install an evaporator without pressure checking. I know some guys do take that risk but these evaps can look brand new from the outside and be corroded from the inside. Never know for sure until it's pressure tested
Old 08-12-2017, 05:26 PM   #10
F.A.A.benny
Also I'd remove the expansion valve to flush and pressure check
Old 08-12-2017, 06:59 PM   #11
lugnuts09
What type of shop can I get that done at?
Old 08-12-2017, 07:59 PM   #12
F.A.A.benny
Not sure but if you can't find one, you can send it to me..I do this all the time
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
