Old 07-16-2017, 06:36 PM   #1
NeverDone50
Swapped the 235 for a 292, need some tuning info
A 292 from a 67 c20 with 46k original miles was practically given to me so I've done the swap and the motor runs good. I just can't find what the idle rpm, dwell, etc. are to tune it up right.
NeverDone50 is offline   Reply With Quote
Old 07-16-2017, 09:44 PM   #2
1project2many
Re: Swapped the 235 for a 292, need some tuning info
Dwell is the same as your 235, 32 degrees. Point gap is .019" new, .016" used. Timing set at 4 deg BTDC @ 600 rpm. Plug gap is .035".
HTH
1project2many is offline   Reply With Quote
Old 07-17-2017, 10:05 PM   #3
NeverDone50
Perfect, thanks! I'm about ready to get this thing on the road.
Old 07-18-2017, 11:45 AM   #4
OrrieG
OrrieG's Avatar
Over at stovebolts there is a good tech article on converting a later model HEI to use in earlier sixes if you want to go that route.
https://www.stovebolt.com/techtips/HEI_mini.html
OrrieG is offline   Reply With Quote
Old 07-18-2017, 08:05 PM   #5
55dude
55dude's Avatar
here is a tech article i wrote up 10 years ago on the H.A.M.B to put a 250 gm HEI in a 235 chevy for future reference, cheap and easy! https://www.jalopyjournal.com/forum/.../#post-2039642
55dude is offline   Reply With Quote
Old 07-18-2017, 08:06 PM   #6
55dude
55dude's Avatar
any pictures of the engine,transmission mounts? sounds cool!
Old 07-18-2017, 11:46 PM   #7
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Thanks 55Dude, I saved that as one of my watched pages on the HAMB.
GreasyLikeaBurger is offline   Reply With Quote
Old 08-08-2017, 10:22 PM   #8
NeverDone50
Not the best of pictures, but I modified the original cross member that the bell housing sits on and then boxed in the frame. I bought a pair of sbc motor mounts made for my truck, but had to slightly modify them as well. Overall, it was not too hard for this rookie mechanic.
Old 08-29-2017, 11:18 PM   #9
evilokc
I always wanted to pump up a 292 and maybe turbo it for my truck. they are cool motors man.
evilokc is offline   Reply With Quote
Old 08-29-2017, 11:52 PM   #10
Dan in Pasadena
Dan in Pasadena's Avatar
Guys used to really hotrod the 292 and big GMC sixes (300+ cu. in.) I had a buddy with a '66 C10 with a solid running 29 and a 700R4 behind it. That truck ran great and pretty damn strong too.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
