Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-21-2017, 01:09 PM   #1
RMBLFSH
Battery draw! Electrical help needed.
This junction, (with the yellow sleeve) connects to two wires. One has a blown fuse. When connected to the positive battery terminal, it puts a significant parasitic drain on the battery. Questions: what circuit has the blown fuse. Where does the other wire (with the thick sleeve on it) go?
RMBLFSH is offline   Reply With Quote
Old 07-21-2017, 02:12 PM   #2
harpo231
harpo231's Avatar
Re: Battery draw! Electrical help needed.
Is that an inline fuse or from the fusebox ? sound like a short
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-21-2017, 02:40 PM   #3
randy500
The fuse is one side of the circuit for the amp meter, there is another similar fuse near the voltage regulator. If the large sleeve piece goes to the terminal block by the battery then I think it is main power into the fuse block.
randy500 is offline   Reply With Quote
Old 07-21-2017, 02:43 PM   #4
randy500
I think the voltage regulator can malfunction and cause a draw on that fused circuit, check with ammeter hooked to that wire and disconnect the 4 wire plug on the voltage regulator.
Old 07-21-2017, 04:27 PM   #5
RMBLFSH
Yes, the fuse is in-line.
Old 07-21-2017, 04:38 PM   #6
RMBLFSH
That's it!
When I unplug the voltage regulator, the parasitic draw goes away.
Thank you.
Now I'll replace the fuse and have the regulator checked at O'Reilly's.
Wish me luck...
Old 07-21-2017, 05:21 PM   #7
demian5
demian5's Avatar
Originally Posted by RMBLFSH View Post
That's it!
Thank you.
Wish me luck...
There are 2 fuses, one on each side in the same place BTW...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale (grandpa truck)
1964 Impala SS
1959 Austin Healey 100-6 BN6
C10s of OC
demian5 is online now   Reply With Quote
Old 07-21-2017, 06:25 PM   #8
randy500
I should have added that the regulAtor is directly hooked to the alternator so unplugging the alternator wires could remove your draw too, not sure how to isolate regulAtor and alternator
Old 07-21-2017, 11:25 PM   #9
Rufas
Rufas's Avatar
If the regulator checks out ok, then you might have a bad diode in your alternator. A simple check of each diodes front to back resistance will identify which diode. Using a DVM check the resistance then reverse the leads. You should get very low resistance and reversing the leads should give a much higher resistance. If the resistance is about the same then the diode is bad and could be leaking current.
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
Old 07-22-2017, 12:21 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Excellent advice in this thread by all.
The OP can also get a digital regulator if he wants to keep the stock alternator.
If he wants to upgrade to the internally regulated alternator I recommend this thread.
.http://67-72chevytrucks.com/vboard/s...d.php?t=417872
And a lot of information on the battery gauge wiring.
http://67-72chevytrucks.com/vboard/s...d.php?t=393139
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
