Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-30-2017, 02:35 PM   #1
snj8198
snj8198's Avatar
isolator with multi position switch
Hi gang,
How would I wire up the switch in pic A to work with relay isolator in pic B?
A:
https://www.bluesea.com/products/300...ith_AFDhttp://
B:
http://www.nvx.com/bir500-500-amp-relay-isolator/
I am running the starter and truck off the primary battery, and have the winch and auxiliary components running off the auxiliary battery.
I want to isolate the batteries, charge them both at the same time, yet be able to manually switch between them in case the primary ever goes dead and I need to use the aux to jump the truck, and turn them both off if necessary.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 07-31-2017, 05:32 PM   #2
lsversaw
lsversaw's Avatar
Re: isolator with multi position switch
Does this answer your question?...
https://www.bluesea.com/systems/39/M..._ACR_SubSystem
Radio restorations
AM/FM/Bluetooth/USB/smartphone conversions
Every modern radio feature in your original radio!
scott@versaw.net
lsversaw is offline   Reply With Quote
Old 08-01-2017, 05:12 AM   #3
snj8198
snj8198's Avatar
i found that diagram too after i posted. thanks for the conformation.
Old 08-02-2017, 10:44 AM   #4
lsversaw
lsversaw's Avatar
I was poking around on the Blue Sea site and found this. It might do everything you want in a single unit, without a separate switch. It also allow self-jump starting without getting out of the driver's seat:
https://www.bluesea.com/products/762..._-_12V_DC_500A
Radio restorations
scott@versaw.net
Old 08-04-2017, 10:03 PM   #5
drfloyd
You can do all of that with a starter solenoid and a remote switch inside the cab. Obviously, the difference is that you would need to energize the solenoid to charge the aux battery.
drfloyd is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
