Old 07-30-2017, 04:34 PM   #1
bluex
bluex's Avatar
Sealing a hole into the water jacket
I was drilling the two additional holes needed in my passenger side head for a serpentine accessory bracket (96+ style). The lower hole wound up in the water jacket.
Should I seal this with a pipe plug now an rely on the two upper bolts to hold the bracket or keep on going to thread size an use thread sealant on the mounting bolt on install. I stopped on this hole at the 1/8 size I was using for the pilot.
I really dont want to deal with this seeping coolant constantly....
bluex is offline   Reply With Quote
Old 07-30-2017, 07:06 PM   #2
jjzepplin
jjzepplin's Avatar
Re: Sealing a hole into the water jacket
I just screwed a stud in with RTV on it and no problems. I made sure the stud had just enough threads to bottom out at the back of the hole. This way the un-threaded part seals pretty good up against the head. Never dripped a drop. Next time I drilled with a stop but still hit it. I guess all heads are cast different. That one doesn't leak either.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
58 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=756563
jjzepplin is online now   Reply With Quote
Old 07-30-2017, 07:39 PM   #3
bluex
bluex's Avatar
Ya I had a stop on my drill bit to but I was still a long ways from it. I'm thinking I'll do it to 5/16 instead of 3/8 an see what happens from there...
Old 07-30-2017, 07:52 PM   #4
jjzepplin
jjzepplin's Avatar
Mine are both 3/8". Only really supposed to hold about 13 lbs of pressure. No big wup. Water pump bolts go thru jackets.
Old 08-01-2017, 03:27 PM   #5
kwmech
Same here---- I just used sealer on a stud
Old 08-01-2017, 06:17 PM   #6
DieselSJ
I had that same mishap drilling the same hole. I used some of the teflon thread sealant and it never leaked a drop. Remember that there are a lot of engines that have bolts that thread into water ports. It really is nothing to worry about.
87 R30 CC Dually, 454, TH400
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 08-02-2017, 07:26 AM   #7
bluex
bluex's Avatar
Thanks everyone, it just freaked me out a little I guess. I may not drive my truck everyday but when I do drive it, it will usually be at least a 50 mile round trip. Its been dead nuts reliable for the last two years so any change I make I'm worried I will cause a bigger issue that leaves me stranded somewhere. My local club does crusies all the time and I dont want to be "that guy" that breaks down...
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
