Old 07-31-2017, 08:59 AM   #1
panhead59
lowering blocks
I;m getting ready to do a 4/6 lowering job on a 68 swb. I've read that it would be best to use the longest REAR spring (4" drop) and a 2" block to give me the desired 6" total drop in rear. But then I've read that 1 1/2" blocks are about the max if I wanted to use 15" wheels. Can anyone confirm this ? I really don't want to use huge wheels, I'd rather have the "old" look as far as wheels are concerned. Just 15" Cragars are what I have in mind. Maybe I just need to look more closely at different wheel sizes (pics) and compromise. Whadaya think I should do? Just go with the 6" drop springs and not worry about the wheel size?
panhead59 is offline   Reply With Quote
Old 07-31-2017, 11:01 AM   #2
hewittca
hewittca's Avatar
Re: lowering blocks
The concern with using drop blocks and smaller diameter wheels is the scrub line. As in, if the tire were to essentially come off the rim, what would touch the ground first? You want it to be the rim and not any fixed part of your suspension. With smaller diameter wheels, you run the risk of the u-bolts being the first point of contact with the ground, not your rim. That would be a rough ride! What you can do is measure your current u-bolt to ground and rim to ground distances. Whatever the difference is between those two (where your u-bolt to ground should be the larger of the two), that is the absolute maximum block height you could use. If it's less than two inches, you definitely don't want to use 2" blocks. All that said, I think there are quite a few guys running 2" blocks on 15" rims, so you should be ok. It is good to check though.
Build: Green Gus
Instagram: @dr.hewitt
Concept Photos: Master Thread
hewittca is offline   Reply With Quote
Old 07-31-2017, 05:28 PM   #3
panhead59
Re: lowering blocks
Thank you sir.
Old 07-31-2017, 08:21 PM   #4
PGSigns
PGSigns's Avatar
Re: lowering blocks
Blocks also move the rear ahead a bit so keep that in mind. You will want to look at the pinion angle. I have three degrees milled off the top of my blocks. They started life about 1 1/4" tall before I cut them. I have 5" springs and the blocks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-02-2017, 08:47 AM   #5
panhead59
Re: lowering blocks
Whats wrong with just using the 6" drop springs ? Sounds like less "hassle", less problems. Plus I can get everything in a kit that way. I see no blocks in any complete kit, so going that route means buying everything separate. It's just a tad worse ride? Or a REALLY noticable difference? I mean- it's a truck!!!! I ain't really worried about being comfortable.
Old 08-02-2017, 09:36 AM   #6
hewittca
hewittca's Avatar
Re: lowering blocks
I don't have any experience with the 6" springs versus 4" springs and blocks, so I can't comment there. The general consensus is just that the 4" springs plus blocks setup gives you more spring travel and should be a better ride, but the better ride part is subjective. For me, I have a different reason for using 4" springs and blocks over 6" springs. That is, I still use my truck as a truck and need the extra travel for when it's loaded up. Plus, you can get 4" drop HD springs, whereas the 6" springs are just a smaller wire diameter spring not really meant for heavy loads.
Build: Green Gus
Old 08-02-2017, 11:32 AM   #7
SCOTI
SCOTI's Avatar
Re: lowering blocks
The best ride will come from the correct shock & the longest shock stroke possible.
Budget approach 4" springs & 2" blocks vs just 6" springs yields longer shock travel thus a better ride.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 08-02-2017, 05:26 PM   #8
panhead59
Re: lowering blocks
What's the "non budget" approach? Air bags? Truck will have new wood bed, so no hauling. Just a Sunday toy.
Old 08-02-2017, 05:30 PM   #9
SCOTI
SCOTI's Avatar
Re: lowering blocks
I would do bags if it's still going to be used as a truck. Springs & blocks otherwise.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-06-2017, 10:00 AM   #10
panhead59
Re: lowering blocks
OK tks guys. Now how do I buy these blocks? CCP and ece websites say they make em but can't seem to find them on there website. How to order and where?
Old 08-06-2017, 11:42 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
Re: lowering blocks
supporting vendors:
http://67-72chevytrucks.com/vboard/s...454824&page=18
https://www.performanceonline.com/60...rear-aluminum/
http://www.brotherstrucks.com/63-72-...tinfo/LBU6372/
CPP:
http://www.classicperform.com/Store/2016/CP39028.htm
You could probably call ECE and see if they have them if they aren't on the website...
Adam
1969 Chevy CST/10 stepside, Dart 532"BB/TKO600
1965 Chevy Bel Air Wagon, 350/TH350, factory a/c
1961 Chevy Bel Air Sport Coupe, ZZ454/M21
2005 GMC ccsb 1500, 5.3/3.73 G80, tow pkg
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
