Old 08-01-2017, 10:44 PM   #1
thatcherkozal
thatcherkozal's Avatar
33x13.5r15 Tires
I was wondering if anyone has ran 33x13.5 tires on their rig, I'm going to do either a 2" or 4" lift, and taking the wheel tire combos I can run into consideration.
thatcherkozal is offline   Reply With Quote
Old 08-02-2017, 11:00 AM   #2
Steven B
Steven B's Avatar
Re: 33x13.5r15 Tires
I run 33x12.50x15 without any lift.
70 Jimmy 4x4
71 GMC 2500
Too bad stupidity isn't painful
Steven B is offline   Reply With Quote
Old 08-02-2017, 11:03 AM   #3
thatcherkozal
Any rubbing issues?
Old 08-02-2017, 01:29 PM   #4
Lieferson
Lieferson's Avatar
stick with a 4" BS on an 8" wheel and you shouldnt have any rubbing issues, as long as your suspension isnt toast.
1972 K10 350/700R/205/ Sniper EFI Daily Driver
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 08-02-2017, 01:37 PM   #5
truckster
truckster's Avatar
Same here, no rubbing. One consideration is going to be wheel width. I have GM truck rally wheels - they're 8 inches wide. Most tire manufacturers recommend going no more than 12.5 tire width on an 8 inch rim.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 08-02-2017, 05:23 PM   #6
72gmguy
72gmguy's Avatar
I had 33x12.50 tires on my 70 blazer and they rubbed on full lock at stock height. I installed a 2 inch lift and no problems since. Here is a pic with the lift. I think my sig photo is 33s without a lift.
Jeremy
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires
1970 4x4 suburban w/ 6in lift and 35in tires
1972 c/30 ramp truck
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 08-04-2017, 01:04 PM   #7
codejitsu
From personal experience, if you are doing any freeway driving in your blazer don't go with a 13.5 wide tire. It will pull you all over the road. Stick with a 12.5 or better yet a 10.5. But for a simple no frills trail rig 13.5 on an 8 or 10 inch wide wheel will work just fine.
'72 Blazer DD 33's
'78 F-250 w/ 1 tons and 37s
'41 olds 98 on bags
2011 vw jetta (wifes)
codejitsu is offline   Reply With Quote
Old 08-04-2017, 05:49 PM   #8
hemi43
hemi43's Avatar
33 X 12 1/2 on mine with stock lift and no rubbing issues at all. I can cruise 75 MPH with no handling issues. 13 1/2 might be pushing it !
The one that dies with the most tools, wins !
hemi43 is offline   Reply With Quote
Old 08-07-2017, 08:07 AM   #9
Mike C
Mike C's Avatar
I ran 33 14.5 Mickey Thompsons on my Jimmy with an 8" rim. They rubbed on the leaf springs when turning and they rubbed on the inside of the tub in the rear of the tub as well. 10" rim would probably fix that.
I think 4" lift is too much with 33" tire so I'd go two. If you go to 4 then 35's. Have a project Jimmy for my teenager that we bought 4" springs for because the lift was on sale at almost half of what the 2 1/2" was. So I guess that means 35's!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
