Old 08-04-2017, 09:43 AM   #1
J king
Steering box removal
Hi all. I have a 51. How does the column come off the steering sector? I can usually figure stuff out but I'm stumped. Thanks. Jim
J king is offline   Reply With Quote
Old 08-04-2017, 09:56 AM   #2
MARTINSR
MARTINSR's Avatar
Re: Steering box removal
The whole thing comes out as one. You leave the column on it, remove the steering wheel, bracket under the dash, drag link from the pitman arm and unbolt the box from the frame and pull the column out of the firewall with the box.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is online now   Reply With Quote
Old 08-04-2017, 09:58 AM   #3
Cuttin up
Cuttin up's Avatar
Its one piece, or at least my 54 is/was. I wasn't going to use it anyway (it was worn out and in terrible shape) so my little buddy mr sawzall helped me out.
my 54 s10 build
Cuttin up is offline   Reply With Quote
Old 08-04-2017, 10:25 AM   #4
mr48chev
mr48chev's Avatar
The way MartinSr said to do it is the right way. You may want the front end of the truck raised up pretty good for clearance though.
Unless it is a worn out junk box I wouldn't take it apart or cut the column and shaft to get it out. The lazy guys cut the shaft and ruin the box for anyone else who might need it. I've even seen a few rolling chassis for sale with the column cut off because the guy who took it apart was too lazy to do it right.
My ongoing truck projects:
Old 08-04-2017, 01:18 PM   #5
MARTINSR
MARTINSR's Avatar
YEP, WORD!
Just do it right, it's simply "different" work than doing it wrong. SOOOOOO often doing something wrong to save time saves NOTHING, you are just doing it different that's all.
Just remove it in one piece like you are suppose to and it's really pretty easy, it just seems odd.
Brian
1948 Chevy pickup
Old 08-05-2017, 06:58 AM   #6
pvienneau
pvienneau's Avatar
http://chevy.oldcarmanualproject.com...51ctsm0904.htm
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
