Old 08-06-2017, 10:03 AM   #1
68gmsee
Active Member
68gmsee's Avatar
Sealed Power Pistons?
Anyone have experience with this brand? I see them advertised quite a bit.
I'm waiting for the weather to cool down some so I can start back on my 350 in the garage. It's been bored .030 over and is not going to be performance engine.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-06-2017, 10:15 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Sealed Power Pistons?
Many people have. What is the engine combo you are thinking of putting together?
Old 08-06-2017, 10:49 AM   #3
68gmsee
Active Member
68gmsee's Avatar
The engine is a stock 77 Impala 350 with 4 barrel Quadrajet. Strictly for occasional driving for my 69 when completed. Heads are also stock out of the same engine.
Last time I had new pistons on an engine was about 15 years ago and don't even remember the brand I used then.
06 Trailblazer
Old 08-06-2017, 10:53 AM   #4
Stryder67
I have a set of flat tops hypereutectic's in my 355. Never had a problem with them. They are good pistons for a street engine that doesn't see a lot of rpm.
Stryder67 is offline   Reply With Quote
Old 08-06-2017, 11:21 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Haven't found any negative articles about them. I did find that Sealed Power and Speed Pro are made by Federal Mogul. Reasonably priced also.
06 Trailblazer
Old 08-06-2017, 11:30 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Btw: What's the going rate to have the connecting rods removed from the old pistons and new ones put on? The last ones I had done the shop did the engine re-boring and piston swap together.
I see a lot of Youtube videos for doing it yourself, but I don't want to mess with at this time.
06 Trailblazer
Old 08-06-2017, 10:04 PM   #7
gvw5400
gvw5400's Avatar
If these are the old forged pistons sold under the TRW name they are great!
I have had a set in a 0.060" over 396 and they have survived well.
These are probably more piston than your application needs , but if your bore to piston
clearance is machined correctly they will be great and strong!
All the best,
Dirk
gvw5400 is offline   Reply With Quote
Old 08-07-2017, 05:31 AM   #8
GRX
GRX's Avatar
Sealed Power slugs. Built hundreds of engines with them - 2256F (forged). No complaints.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-07-2017, 11:05 PM   #9
Backpayne
I hope they are good. I just bought a set for my 455!
Backpayne is offline   Reply With Quote
Old 08-07-2017, 11:55 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I bet I've put them in at least a dozen or more engines. Good pistons!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-08-2017, 08:33 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Thanks for input. I'll ordered a set...
Also found out a local small machine shop will remove old pistons and install new ones for $40 a set.
06 Trailblazer
Old 08-11-2017, 12:31 PM   #12
68gmsee
Active Member
68gmsee's Avatar
Engine is a 350 bored .030 over and is for an occasional driver/street use.
Ordered a set of sealed power hypereutectic cast pistons from local auto parts. Came as a set with wrist pins and rings and had to return the set.
Reason for return:
Pistons fit fairly decent with a tight .002 feeler guage on one side of the skirt. Measuring piston vs skirt width with two digital micrometers showed a .0015 difference which was withing specs. However, the rings showed a wide gap of .040 +/- .005 on several cylinders.
In the past most rings I've bought have had to be filed slightly to gap them correctly so I figured they had sent the rings for a standard 4.00" bore. The .040 ring gap would have been about .010 in a stock block.
06 Trailblazer
