Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-06-2017, 04:46 PM   #1
Karlwebb81
Headlights Stopped working
Hey Chevy People,
My headlights on my '72 c10 took a dump all of a sudden last night. The toggle switch looks good, and other lights (dome, parking, etc.) work fine. Have any of you got an idea what might have happened/what to do?
Karlwebb81 is offline   Reply With Quote
Old 08-06-2017, 05:20 PM   #2
rockyrivermark
Re: Headlights Stopped working
use a tester for power at the socket.
If you have power at the socket then it's a fault in the ground
Bad ground is often the culprit.
Also check socket plug connector for corrosion.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 08-06-2017, 05:21 PM   #3
dmjlambert
dmjlambert's Avatar
So you have a toggle switch?
You should use a tester to see if you have voltage at the headlights and along the wires that go to the headlights.
dmjlambert is offline   Reply With Quote
Old 08-06-2017, 06:42 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
My headlights [Hi + Lo] went out when my dimmer switch went bad. That's the toe-operated one on the floor, left of the clutch pedal. Or Brights/Dim switch.
R + R'ed the dimmer switch and the lights worked normal again.
Old 08-06-2017, 08:42 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Could be any number of things but the most common problem seems to be the dimmer switch or the wiring / connector at the dimmer switch.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-06-2017, 08:51 PM   #6
bill3rail
bill3rail's Avatar
Welcome to the boards!
Multi-meter's are your best friend, but start in reverse from ground then chase positive!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is online now   Reply With Quote
Old 08-06-2017, 09:12 PM   #7
70 shorty
Where's my beer?
70 shorty's Avatar
A new dimmer switch fixed my headlights that stopped working years ago.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
70 shorty is offline   Reply With Quote
Old 09-25-2017, 09:20 AM   #8
Karlwebb81
Thank you for your advice, it was the dimmer switch. The wires under the carpet looked like a birds nest, a little TLC and the lights work great. THANK YOU
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
