11-08-2012, 06:57 PM | #1 |
Parking light question.
Just had a Painless harness installed and my parking lights cut off when I turn on the headlights. Is it supposed to do that? I though they stayed on? Truck is a '70...w/ '71-'72 grill and bumper if that matters but pig tails and all should be the same, right?
Posted via Mobile Device Last edited by LEX; 11-08-2012 at 07:50 PM. |
11-09-2012, 12:27 AM | #2 |
Msgt USAF Ret
Re: Parking light question.
The 69 and newer trucks were wired to have the parking lights on anytime the light switch is in park or on headlights. Yours should be on with the headlights. The switch in you truck might have been changed to an older style. This picture shows the older style.
And this one is the newer style. See the note on terminal 7
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-09-2012, 11:21 AM | #3 |
Thank you, VetteVet. I'll take a look and see what switch I have. If it's the right one, then I have another problem.
11-09-2012, 11:31 AM | #4 |
way back in the mid 80s i did a cab change on a 72 with a 67 cab and put a jumper wire from the park lights to the tail lights at the switch ran it like that for many years never a problem
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
11-09-2012, 12:49 PM | #5 |
Msgt USAF Ret
I re-read your post and I'm not so sure that you have the wrong switch because if the Painless harness is for the 69 and up trucks It wouldn't fit the older switch, I don't think it will anyway.You may have gotten the older harness and the jumper will fix it. There aren't a lot of differences between the older harnesses and the newer ones. You'll just have to check out the light switch. If you have the newer switch and the harness to match then we'll have to go from there.
11-09-2012, 08:57 PM | #6 |
Thanks, guys. I'll check it out.
02-13-2018, 08:15 PM | #7 |
digging up old thread...and hoping for some advice
I have the opposite problem...I have a 67 and the parking lights are staying ON when the headlights are on (subsequently I don't get any blink when the headlamps are on) The PO put in a Painless wiring kit and fuse block. any suggestions on how to get it to behave like a 67?
JMC1965 1967 C20 LWB
