09-14-2018, 03:43 PM | #26 |
driving is in my blood
Re: 383 rod recommendedations
Has anyone actually done this without needing a small base circle cam? I couldn't spin my engine over with the standerd cam.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-14-2018, 11:24 PM | #27 |
60-66 Nut
With a standard base circle cam, you have to grind on the heads of the rod bolts and rods to achieve ~.050" clearance.
09-15-2018, 03:43 PM | #28 |
It really depends on the cam grind. Not gonna hurt to go ahead and order a small base circle cam especially if you're going roller. I would run the scar or eagle capscrew I beam rods as they I'll have more clearance up by the cam. The crank you have with a 3/8 cap screw rod and a sealed power h860cp (flat) or h859cp (dish) piston will make for a super easy balance job. They're usually within 10 grams... There are also plenty of pistons for a 6' rod but they will be forged. The 6" rod will have more cam clearance than a 5.7
