01-17-2019, 11:59 PM | #1 |
Will these wheels fit a 1979 GMC 1/2 ton?
Hey guys,
I have searched the forums here and have not got a definitive answer, so here I am. I am wanting to know if these wheels will fit my 1979 GMC 1/2 shortbed. Discs up front and drums in the rear. https://www.ebay.com/itm/302912802394?ul_noapp=true I asked the seller on flea bay and he said they would fit fine, but when I looked at all of the compatible vehicles on their list, they were all 2009 and newer Dodge, Jeep, Volkswagens with 5x5 bolt patterns. The center bore size seems to be plenty big enough at 83.1mm, but I don't know. The holes for the studs may be off in size, but again I am not certain. All the research I have been able to find says that 5x5 wheels for GM / Chevy trucks are interchangeable from 1971 to 1998, that's it. So the fact that all of the vehicles are on their interchange list are 2000 and newer, it has me concerned. Guess I may just call American Racing in the morning and find out directly from them. Thanks to any of you that can shed some light on this. Brent |
01-18-2019, 06:08 AM | #2 |
Re: Will these wheels fit a 1979 GMC 1/2 ton?
Welcome.
The bolt pattern should be fine. not sure of the center bore. the m manufacturer would be a bettter source on that info. I would give them a call. However, the width size may look a little small for the truck. 8 inch might look better depending on the look you're going for.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
01-18-2019, 07:00 AM | #3 |
I'm sure they will fit but I don't know the look you're going for either. What size tires are you planning to run?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-23-2019, 02:01 PM | #4 | |
77 c10 LWB 96k original miles, 454ci w/dual Flowmasters and Flowtech headers, Truxedo tonneau cover and 15" American Racing Torq Thrust rims on BF Goodrich Long Trail TA's. She's called Ol' Red. Learning to laugh at yourself makes it "open season" on everyone else! |
