07-16-2017, 10:15 PM | #1 |
C4 R&P input shaft?
Iam useing an '88 C4 R&P with on my TF pickup. The input shaft is a DD shape. It measures just under .7 inches, is that the same as 3/4" DD? Or is it a metric of some sort. What are you C4 guys useing for that connection? Thanks
07-16-2017, 11:57 PM | #2 |
Re: C4 R&P input shaft?
It's 17mm DD. I used a Borgeson U Joint 17mm DD to a 3/4 DD. Borgeson has a great selection of conversion steering U Joints.
07-17-2017, 12:00 AM | #3 |
Hollister Road Co.
If your going to 3/4 DD shaft you would need a 17mm DD to 3/4 DD adapter, ujoint or coupler or use a 17mm DD shaft to the column and get a 17mm to 1DD Ujoint
07-17-2017, 12:42 AM | #4 |
Thanks guys, i suspected it was something like that.
