Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-13-2017, 02:30 PM   #1
nikwho
nikwho's Avatar
How to wire electric fans to stay on for a few minutes after engine is shut off?
Hello all,
I've currently got my electric fans wired to a relay with the trigger wire hooked to a constant 12v, switched by a 180°temp switch, so that the fans continue to run after I shut down. However, my radiator doesn't have a bung for the temp gauge, so the fans run until the coolant in the intake manifold is under 180°, which takes a fair bit of time. I don't want to end up with an issue that drains my battery, so I'm wondering how to wire this thing so that it runs for a set amount of time after I shut down? Is there anything that I can install that gets 12v and shuts piwe off after a set amount of time after it stops receiving power from the ignition?
Thanks,
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 11-13-2017, 02:55 PM   #2
gmachinz
Re: How to wire electric fans to stay on for a few minutes after engine is shut off?
I've got delay off headlight kits available and the same method of activation could be used for your cooling fan(s) as well. Its more of a race oriented relay control fan harness but it would do what you want. Its a solid state circuit design and is adjustable from 0-900 seconds after ignition off, for example.
gmachinz is offline   Reply With Quote
Old 11-13-2017, 04:21 PM   #3
nikwho
nikwho's Avatar
That sounds like something that would work! Have a link or any more information?
'68 GMC - BBC/TH400
Old 11-15-2017, 10:29 AM   #4
jbarron
There is a time delay relay that will do this.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 11-16-2017, 10:41 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
In my opinion it is a waste of time and energy to run the fan after the engine is shut off.
The fan will only cool the liquid in the radiator because the water pump will not be sending fresh hotter coolant into the radiator. The cooling effect will be done by thermal conduction from the hot manifold coolant to the radiator until the thermostat closes, and what can cool from heat flow from the water pump. This will take some time and it will cool anyway as the engine block cools.
I would just rewire the relay to shut down with the key and the cooling sensor.
Does anyone know if the car manufacturers are setup for the fans to run after engine shutdown?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-17-2017, 12:33 AM   #6
gmachinz
For some reason I thought the OP was running an electric water pump too-but I guess not. If you were, you could run 2 control relays together for the fans and water pump to be triggered with delay via a solid state relay-but if running a mechanical fan then as Vette said-not worth the effort.
Old 11-18-2017, 01:49 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: How to wire electric fans to stay on for a few minutes after engine is shut off?
Late model fans can come on anytime the set points are over the setting without the key on.
I have mine wired with a temp probe in the 64 and 56 that will allow the fans to stay on until the temp is below the on set point.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-23-2017, 11:49 AM   #8
Willie Makeit
Willie Makeit's Avatar
why would one want to continue to cool the water in the radiator after the engine is stopped?
Willie Makeit is offline   Reply With Quote
Old 11-23-2017, 12:49 PM   #9
gmachinz
For the majority of people its a drag race thing-cooling it off between runs after sitting and running waiting to run. For the street while it'd be cool to do (pun intended!) theres not a good way to run an electric water pump.
Old 12-08-2017, 07:46 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: How to wire electric fans to stay on for a few minutes after engine is shut off?
The probes are set to kick the fan on low at 180* automatic. If the car is over 180* when you turn the key off it will run until it cools it down enough.
It so I don't have to worry about a switch on the dash to do it myself.
Old 12-08-2017, 07:55 PM   #11
gmachinz
Just fyi...push-in style probes are accurate to +\- 10 degrees whereas a temp switch is +\-3 degrees. Sounds like you basically have the fan wired the way which works for ya-are you using a deep cycle battery or no?
Old 12-27-2017, 01:19 PM   #12
Andy4639
Old member
Andy4639's Avatar
No deep cycle just regular battery. The cooling effect after the motor is shut off is min. so if everything is working like it should the temp will be close to the 180* so that the fans only run for a few seconds after the motor is off.
I have drove them both and waited to see how they do and the most time the fan stayed on was 1 minute.
Old 01-23-2018, 06:34 PM   #13
87Skier
87Skier's Avatar
If you want them to stay on, you will probably need a delay like gmachinz mentioned if you want to keep your existing circuits.
You could buy a temperature control device like others have mentioned.
If you want, I can post a guide on how to make to a circuit interrupter that opens your switch ground so that the fan turns off with the key. I had to do this with my setup, otherwise the fan would run for about 15 minutes after I turned the key off.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
