12-19-2018, 09:07 AM | #1 |
Negative battery cable
This is going to sound like a dumb question but can someone tell me where the main negative battery ground connects to on a 94 305? I removed my intake manifold to replace the gaskets and I can't remember where it was connected.
12-19-2018, 10:33 AM | #2 |
Re: Negative battery cable
It can ground on one of the intake manifold bolts or the front of the block at the bottom.
Mike |
12-19-2018, 11:04 AM | #3 |
From the factory the battery ground was on an intake bolt to the passenger side of the thermostat.
Here are links to photos of a 1994 and a 1993. Look at post 8 http://67-72chevytrucks.com/vboard/s...php?p=7069544# http://67-72chevytrucks.com/vboard/s...d.php?t=315006
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 12-19-2018 at 11:11 AM. Reason: Fix link |
12-19-2018, 11:48 AM | #4 |
Awesome! Thanks guys it looks like I guessed correctly.
