Old 09-21-2012, 10:12 AM   #1
91Subbed
O2 sensor on headers
I just installed long tube headers on my 1991 suburban 350 2wd, I was wondering what to do with the o2 sensor? Ive heard use the stock single wire one in the header collector or put it on tube #4 or #8. I've heard use a 3 wire sensor. Any help with this problem? Thanks!
91Subbed is offline   Reply With Quote
Old 09-21-2012, 12:20 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: O2 sensor on headers
I didn't know those needed to be tricked. You can't just add a bung to one collector and reuse the original o2 sensor?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-21-2012, 12:24 PM   #3
91Subbed
That's what I'm hoping to do, but the research said its ideal to go with a 3wire o2 sensor. Idk that's why I'm trying to get any input I can. Thanks for the response!
Old 09-23-2012, 02:34 AM   #4
Rogue_Alphonse
Rogue_Alphonse's Avatar
Just weld the nut all the way down by where the collector bolts to the exhaust and extend the wire [wrap it with something heat resistant too!] I did it with a new o2 and it works fine!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 09-23-2012, 11:21 PM   #5
cal30_sniper
cal30_sniper's Avatar
x2
No need for a three wire heated O2 sensor unless your vehicle originally came with one.
-cal30sniper
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 09-24-2012, 12:15 PM   #6
Mike Nixon
I put an H pipe in the exhaust just past the collectors and install the 02 there if possible. it draws off both banks then and monitors the entire engine.
if you can't do this then just put a bung in the collector and go on. The single wire unit is a good unit for the app they're used in.
Mike Nixon is offline   Reply With Quote
Old 09-24-2012, 01:31 PM   #7
cal30_sniper
The problem with the H-pipe O2 sensor is that your readings are very far removed from what the engine is actually experiencing. There's a time delay for the exhaust to get there, especially considering that you're going to have mixing and stagnation inside the crossover. Heat within the crossover is also much less than the collectors, which could screw up the readings (both actual composition of the exhaust, and what the sensor actually reads).
I would not advise putting the sensor in the crossover. Not saying it won't work, but it's definitely not ideal. The factory sensor only reads one bank, because it is placed as close as possible to the cylinder exit that can still get an averaged bank reading. That is for reasons of both temperature and response time.
Old 09-25-2012, 08:32 AM   #8
Mike Nixon
In theory this is true, and I run the H as close to the collectors as possible. That being said, on my 94 2500 2500 HD with a TBI350, 4L80E, and 4:10 gears, I picked up 2 mpg fuel economy gain with this mod and a true dual exhaust system with hi flow convertors. Readings on the scanner did not change a bit, and the activate time on the O2 from dead cold was the same. It does not drop out of closed loop after the initial warm up. The relocation of this sensor is about 12" farther back than it was in the OE location.
