07-31-2018, 09:29 PM | #1 |
But Found Her 25yrs Later!
Parked in a Field for Over 4 Years.
It's been parked out at my friend's property and not started for over 4 years. We're going to go out there and try and get it started.
I'm taking about 10' of fuel line, a fresh can of gas, a battery, an extra carb, and maybe 10' of wire. Also some tools of course. Am I forgetting anything? That's it with the wood stacked on its utility bed.
07-31-2018, 10:18 PM | #2 |
Re: Parked in a Field for Over 4 Years.
starting fluid, oil filter, brake fluid, points / condenser (or matchbook)
07-31-2018, 10:30 PM | #3 |
Oh yeah, brake fluid.
It has an HEI.
07-31-2018, 10:40 PM | #4 |
Your AAA card
07-31-2018, 10:50 PM | #5 |
Wasp Spray!
07-31-2018, 11:22 PM | #6 |
One foot in front of the other
Add PB Blaster and a weedeater to your list.
07-31-2018, 11:40 PM | #7 |
Great suggestions.
My buddy said if we could at least get it to the main road, we could use his triple A card to to my shop. :-) Very likely we'll need a weedeater and wasp spray.
08-01-2018, 09:32 AM | #8 |
If that truck was left in a Kansas field for 4 years the cab would be filled with rodents. One of the first things we do when pulling a vehicle from a field (or barn) is to leave heavy bowl of antifreeze on the floorboard a week before. Then when you go back and sit in it a rodent won't brush against the back of your leg
Brett | 1966 K20 - 292/SM420/T221 |
08-01-2018, 10:14 AM | #9 |
A portable compressor to fill the tires and a chain to pull it out. They usually sink in the ground around here.
You may also want some water or coolant if you plan to actually drive it.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
08-01-2018, 02:07 PM | #10 |
Check the oil for water first.
08-01-2018, 02:27 PM | #11 |
Small hose clamps for temporary fuel hoses too. I’ve forgotten those little bastards so many times and had them pop off or leak lol but some pb is a good call. And a good pair of vise grips just in case
08-01-2018, 02:39 PM | #12 |
marvel mystery oil, a long neck funnel and spark plug socket set to lube up cylinders. couple gallons of water for radiator and a broom handle in case the hood hinges are wore out, and a .22 to peg the critters coming out of the truck
1967custom |
08-01-2018, 02:45 PM | #13 |
Throw a bug bomb in the cab a run....but
08-01-2018, 10:23 PM | #14 |
Thanks for all the suggestions.
Us old men after spending most the morning on the lake decided we'll just rent a trailer and haul it back to my house.
08-01-2018, 10:53 PM | #15 |
Old and WISE men...
08-02-2018, 08:03 PM | #16 |
4 Years, that's nothing. I pulled my truck out from behind a barn where it had sat for 22 years.
I have changed out the fluids, put on new hoses and belt, new brakes etc. But is is up and running and will soon be my daily driver. Oh, and new tires. I was lucky, mine was here in Yakima Wa. Super dry all year, so the motor spun by hand with ease. They can be resurrected. |
08-03-2018, 01:13 AM | #17 |
It's just been killing me having it sit out there.
I had done so much to it, and i don't want that to be wasted. Mechanically it has all the 73-87 upgrades. 14-Bolt Full Floater. Complete Front Crossmember with New Power Steering and Power Disc Brakes. New windshield rubber. New rear window rubber. New cab mounts. Nice 90's Service Box. And only a few miles on a GM Goodwrench 350. I was restoring it to be a work truck for my construction company. But now having a desk job and my 65 back, I have no need for it, but I can't leave it out there either.
08-03-2018, 07:45 AM | #18 |
Check The Champ, Demonstrator
I like the trailer it home idea. It's like bringing all your tools to the site , in reverse...lol
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-18-2018, 03:10 PM | #19 |
Do you guys think my 65 c10 with a 283, a TH350, and 3:73 rear gears can tow this 66 c20 service truck?
08-18-2018, 03:15 PM | #20 |
With trailer brakes?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-18-2018, 03:44 PM | #21 |
If you have a receiver hitch and trailer brakes, yes. Or do you mean with a tow bar or chain?
08-18-2018, 04:03 PM | #22 | |
And taking the back roads.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 08-18-2018 at 04:22 PM. |
08-18-2018, 04:41 PM | #23 |
what I've gotten away with and what I'd recommend to others are two different animals..
wishin' you good luck and in to see results and pictures..
I started out with nothing - and I still have most of it |
08-18-2018, 07:20 PM | #25 |
Ha! Isn't that the truth.
